Replacing System Drive in v1
FirstStopCentral
Hi All,
I've searched but can't find the answer I need.
I want to move my existing v1 data disks across to a new HP Microserver, so I install the 3 drives
and then do a server recovery to the new system drive and let it rebuild the tombstones, etc.
I can't find however how to remove my existing system drive from the pool before shutting down the
old machine and moving drives. I don't have enough room to duplicate everything and I thought there
was a utility around to force any pool data from the system drive (sure I did this once before).
Not worried about backups, just don't want to lose any data in the pool.
Thanks in advance.
Paul Turtle
Finally found what I was after. The program is called 'drive balancer' and is made to evenly distribute data across your
WHS v1 pool drives. It can optional include / exclude the D: drive, so by telling the program to move all 'data' from the
D: drive, you can then remove the system drive and replace with another drive and do a 'server recovery'.
Paul Turtle
Sydney, Australia
