Should I blow out and rebuild v1
mailman1988
I'm new to the forums, but have been a podcast listener for over 2 years.
My home built is v1. AMD 4200+ (duel core 2.2) 2g ram, 7T HD (1T-system, 2T,2,2). Nic 1gigabit.
My system has been up and running for 3-4years. w/o rebuilds. or issues.
I was thinking of rebuilding my system and replace my os w/ 64G SSD.
Should I and can I do this? or save the SSD to build a HTPC?
The HS just seems dogish when I need to do things on it. Loading the Console takes forever to launch.
If I did rebuild, how do I make sure that I restore all the shared files.
I have done an external back up. but had re-formated that drive, did another back up-will this now be an incremental or full back up? I also use DBBB, but might only want to restore some of the seats.
Thanks guys in advance.
  • Replies 36
  • jmwills
    6
    6
  • Joe_Miner
    8
  • mailman1988
    11
Since you're new to this site -- Welcome -- there's ton's of information here and before starting building anything I'd suggest going thru many of the posts and look at various builds for WHS V1 and 2011 -- there are many and if you're like me you'll enjoy reading thru them and looking at the pictures. Many people also have details of their systems in their Sig lines.
For a server running V1 24/7 I'm not sure the speed boost in a SSD for the OS would actually buy you much in the way of performance that compenstates for where I would be concerned and that is the SSD's apparent less reliable experience that I've seen reported here and elsewhere and it seems when they fail it is quite catastrophic and quick -- something we don't want to happen in a Server with our important/priceless data.
The specs on your current set-up don't seem all that bad. Has your WHS always seem dogish or is that something recent?
Edited by Joe_Miner
My system has been dogish for sometime now. Especially when de is doing it's thing.
I did look at some of the postings about use of ssd in servers, I guess that I figured since I had a 64g laying around that I'd use it in my server. I originally was to use the ssd in my laptop, but it was too small and I came across a 160g for that, pretty cheap and used, but new.
I don't have too many add on's running, I will get a list together shortly. I do have a large video and 10 years of photo's on WHS. Sometimes it takes almost 1 min for the console to load up. Lot's of hd trashing going on.
I do run Diskeeper and norton av-corporate, zumocast,
Also, I asked, since I blew out my original back up, how do I tell the HS to "reset" it's back up state to ensure that it will back up all the files to my external and not just incremental.
I am getting file names to long errors during the back up.
The most cost effective solution would be to double the RAM and as others have said, the SSD in that old of a system is a waste. The data is being read from spindle drives, not the OS drive. Oh...and I just say the dreaded Norton word. I would lose that crap in a heartbeat. If your clients are clean, then so is the data that is stored as long as the server is not used to gather external data.
A fresh install will also do wonders for the system.
Can I do a fresh install and not loose any data?
I'm beginning to see that the SSD is best kept for a HTPC.
I will also dump Norton.
You were/are running Norton?
I would have been a little "afraid" of what Norton would do with/to Drive Extender. How they interace with DE is my big concern with Security SW on V1. 2011 is more like a business system and it should be much easier to find a safe AV pgm.
I have only had experience with Norton's personal versions and only until the last couple of years their overhead was awful -- it still isn't that great. I blew Norton off my main client after discovering some major issues with Norton Utilities. WSE was a huge performance improvement.
On my laptop I blew off NU but still run Norton IS2011 though I know it's dogging my performance on my 1810T.
I've never had Norton on my Revo 3600.
On my Server I'm still holding out with McAfee SaaS since I have a license paid to 2013, it works, and I love my tech support in India :). McAfee also has it's issues and there are many other pgms people use out there on V1.
Edited by Joe_Miner
I haven't tried it, but I would think the following would restore your backups to initial state:
  1. delete all the backups for a client computer
  2. remove the client computer from WHS
  3. remove and reinstall the connector
Seems to me WHS would then think it's a brand new computer and start the backups with a full one.
Your system specs do not seem bad for a V1 build. You did not mention all the add ins. What do you have installed? Add-ins is the number one killer of stability and performance on V1 so you might look there. You mentioned Norton's AV which I do not thing is V1 compatible and Diskeeper which is also very bad on resources. I would uninstall those two and see if that helps then re-install one at a time.
    • Rodf
      By Rodf
      I'm looking into replacing my desktop's old, failing HD with an SSD. I've got a Dell XPS 8700. I've look up the configuration on Dell's website, entering my machine's service tag (DK49122). I've found the component which is listed as:
      KPF74 : Module,Hard Drive,1T,S3,7.2K,5 12E,#1,G-BP INFO,1ST BOOT,HARD DRIVE HD,1TB,S3,7.2K,512E,SGT-GRDABP
      I know it's a 1 TB drive. It looks to me like it's a SATA III drive. Am I correct?
      Assuming I've correctly identified the drive, then I've found what looks like a good replacement part on Newegg which is listed like this: SAMSUNG 860 EVO Series 2.5" 1TB SATA III V-NAND 3-bit MLC Internal Solid State Drive (SSD) MZ-76E1T0B/AM
      So, have a got a good replacement SSD for my machine's old HD?
    • xelent
      By xelent
      Hi there,
      I've just gotten my old Proliant server out from mothballs recently to use as a Backup controller for my photographic archive. It's specs are a standard G840 2.8GHz Dual core with 16 GB of ram installed with a standard 350 watt PSU. I'm running WSE 2019 with 4x1TB HDD's installed in the 4 bay drive cage. 3 drives are formatted to RAID 0 in WSE (not embedded HP RAID) and one drive acts as the system/boot drive.
      The server is surprisingly responsive given its age, with LAN transfer speeds between 84-94MBs. So has pretty much taken center stage in my backup control between my  external drives and 4x1TB RAID 0 NAS.
      However, I have been wanting to attach a 256GB SSD boot drive for my OS, so that I can utilize the full capacity of my 4 bay drive. It seems that the BIOS will not let you boot any HDD/SSD off the spare SATA connection on my MB. Anyway I am hoping to eventually attach a PCIe USB 3 card to that. But in the meantime I would like to boot a separate drive other than the 4 bay one already installed.
      I gather that you can install a PCIe SSD card on this machine. But it's not clear to me as to what kind of card and drive would be suitable for this server. I realize that my MB is PCIe gen 2, which will incur diminished speed compared to the latest gen 3 MBs. But should I be using NVMe or SATA m.2 drives? Or does it even matter? Also will the BIOS allow me to boot from this drive?
      Thanks for taking the time.
    • Karazzi
      By Karazzi
      Hi everyone.
      New to this forum.
      I have a gen8 microserver running at home, where I have installed an SSD in the ODD sata slot. On the SSD I have installed Ubuntu Server 18.04.
      I have then created a logical volume witht the raid controller and can then boot to the SSD. So far so good.
      My problem emerges when I reboot the system. The logical volume disapears and it gives the error: "boot logical drive is configured but is missing or offline".
      I then have to go into the utility and reconfigure the logical volume. Kind of annoying, when trying to run a headless setup.
    • Laris
      By Laris
      Hi all,
      Now I share my extreamly mod for your reference
    • ICYDOCK_Chris
      By ICYDOCK_Chris
      ICY DOCK is the leading expert in data storage enclosures and accessories.
      Introducing ToughArmor
      ToughArmor is ICY DOCK’s rugged enterprise-grade line of 2.5” SSD and HDD enclosures, utilizing the standard external 5.25” bay, external 3.5” bay (floppy bay), and the slim optical bay (ODD bay). All ToughArmor models feature ruggedized full-metal enclosures and trays, to keep your sensitive data protected, as well as meeting many flammability requirements. It features many high-density storage options, supporting as many as 16x 2.5” drives, or as few as one. Models are available to support SATA, SAS, and now, U.2 NVMe drives, giving you flexibility in choosing drives that work best for you. The strength and build quality of all of our products is backed by a full 3-year warranty against all defects. ToughArmor is used and approved by Tier 1 companies such as Hewlett Packard (HP), General Electric, NASA, as well as the US Armed Forces. For more information on our ToughArmor line, read our ToughArmor documentation here. Links to all of the products discussed here can be found in the documentation. All ToughArmor products can be view here.
      ToughArmor for SATA 3.5” / 5.25” Bays
      For SATA and SAS drives installing into 3.5” and 5.25” bays, we have a large number of options available. In the 3.5” bay, there are models that support one to three drives, some with features such as key-lock trays and hardware RAID capabilities. The larger 5.25” bay supports between four and eight drives in a single bay, and up to 16 when using two bays. These denser options offer cooling fans, to keep the large number of drives cool under heavy load. These models have a wide array of uses. The MB991U3-1SB is our portable ToughArmor unit you can take anywhere, and works over USB. The MB992SKR-B is a 2-bay model with a hardware RAID chip, with modes for RAID 0, RAID 1, BIG, and JBOD.
      There are also our more traditional drive carriers that install into a single 5.25” bay. While these models don’t have USB support or a RAID chip, they still have direct SATA connections, the full-metal enclosure, and the 3-year warranty.  The 4-bay (MB994SP-4S), 6-bay (MB996SP-6SB), and 8-bay (MB998SP-B) models are perfect for any general applications that require hot-swappable SATA hard drives and SSDs in a dense storage enclosure.
      ToughArmor for NVME
      Recently, ICY DOCK has released the first-ever hot-swap cages for U.2 NVMe drives.  U.2 drives use the standard 2.5” size familiar from SATA SSDs, but utilize the NVMe specification allowing for transfer rates of up to 32GB/s. ICY DOCK U.2 NVMe cages come in one and four bay models, and utilize a single Mini-SAS HD connection for each drive. The single-bay model (MB601VK-B) fits in a single 3.5” bay, great for space-limited tasks that require only a single drive.  Small-form-factor systems, DVR systems, and photo/video editing systems can benefit from high-performance storage in a small space. If you need more drives, the 4-bay model (MB699VP-B) is the one for you, and even works great in RAID setups.  These are used in datacenters around the world, that need dense NVMe based storage. Both of these models use a Mini-SAS HD port / cable for each drive, so make sure to prepare your system with enough Mini-SAS HD ports.
      ToughArmor for Optical Drive Bays
      ICY DOCK also has several drive cages that fit into slim (12.7mm) and ultra-slim (9.5mm) optical drive bays. These can serve to replace existing drive readers in laptops and desktop systems, and can also be paired with several of our 5.25” bay brackets. Perfect for space-critical applications that require drives to be installed in the smallest possible space. Common uses are in Small-Form-Factor PCs, media PCs, Home Theater PCs (HTPC), and security footage systems. In industrial uses, these are often found in 1U and 2U rack-mounted systems with limited space availability, and portable workstations/laptops.
      If you have any questions about the models mentioned here, or anything else, send us an email at tech@icydock.com. We offer first-class customer support for all our products, from pre-purchasing info, product selection help, walking you through installation, and issue troubleshooting. In addition to email, we offer phone and live web-chat customer support, which can be found here.  Our knowledgeable support technicians are available Monday-Friday from 10:00am-5:00pm PST.
