System disk RAID - Always or if possible?
Server Grunt
Hi,
Looking to build a small form factor high capacity silent WHS 2011.
The Silent part, and I mean silent not quiet, limits choices basically to the HFX PowerNAS box:
http://hfx.at/index.php?option=com_content&view=article&id=421&Itemid=176
It is just what i am looking for, but one thing that is bugging me is that the 2,5" system disk looks like it can not be put in a RAID configuration as it is stuck into a small "pocket" on one side of the case.
My question is: How important in system disc RAID?
Thanks,
Server Grunt
It is not imperative for the System disc to ve put into a RAID configuration, but most of the builds you see in this forum are with mid-ATX and full ATX cases and the room is available. A very small form factor such as the above case does not allow for an extra drive to put the system drive into a RAID 1 configuration. Not a deal breaker as you can always create a VHD image of the installed OS and store it on the data RAID 5.
Just my thoughts....I like the look of that case BTW, but at 995 Euros.....thats a lot.
It isn't a requirement to have RAID for the system disk. I used it as it wasn't expensive, fit easily in the case and was a nice protection in the event it is ever needed.
Guest no-control
RAID isn't required for WHS2011 on the system OS as long as you store no data on that disk. When it fails you can replace it and reload the OS without having data loss issues. But it is highly recommended to maintain uptime of your central storage.
Hi,
http://hfx.at/index....=421&Itemid=176
Thanks,
Server Grunt
With built in server backup, you do not have to raid if you can have your server down long enough to pick up a new drive and do restore. The reason for mirroring the OS is to eliminate that time.
Hi,
Thanks for the replies - I will have to emember not to stuff it with 3TB drives only, but add a 2TB for teh server back-up.
Reg. the case and price. The €995 is the price in a pre-configured i3-based system. The case itself is around €249, not cheap but circumstances dictates this kind of choice.
    • Giuseppolino87
      By Giuseppolino87
      Hi everyone, today I wanted to install esxi 6.7 to try out the various functions, my question is the following, I have a server where I have installed esxi in an SSD and I have two other 4 tb disks so 8 tb total.  I would like to make sure that when I create a virtual machine in this case I will install the various virtual machines in the SSD and use the two disks for data.  So how can I do this?  Thank you very much for those who can help me.
    • E3000
      By E3000
      Looking for a quick answer here from someone in the know...
      I upgraded some of the internals of my Gen8 server and at the same time I did a BIOS reset as I had forgotten the password that I had set years ago. When booting back up the upgraded hardware was detected and fine but I received Error 1784 - Drive Array - Logical Drive Failure. I believe this is due to a setting change in the BIOS and not anything hardware related. I have gone into IP/SSA and see the array needs to be rebuilt. I had all drives configured as single RAID0. It says all data will be lost if I reconfigure this but I remember reading somewhere on here that the data will be fine if I reconfigure as RAID0.
      I do have a backup of course, but it’s not a high availability mirror and will take some time to get back the way I had it, so just want to know if it’s safe to reconfigure the RAID0 without erasing the drives. I have tried pulling the drives out and connecting them to another PC and they are fine. Can anyone tell me which options to choose to get these back to normal and remove the flashing red light?
      Thanks 😶
    • Mark Belanger
      By Mark Belanger
      Greetings,
      I'm new to the HPMSG8 world and so far I'm loving it. I have a stock Xeon with 16G of aftermarket memory with iLO patched to 2.70. Next up is adding a RAID card, so I can put my boot SSD on the onboard RAID. I picked up a LSI SAS9211-8i on Amazon, but am struggling to flash it to IT mode on the MicroServer. Is this even possible? Unfortunately, the only other system I have with PCI slots is 32-bit.
      Any pointers would be greatly appreciated.
      -MB
    • TakiBot
      By TakiBot
      I've got my hands on a HP N40L.
      Can i use raid 1+0 on my 4 2TB WD RED or only 1 and 0.
      Thanks for the help.
    • arefiev.dm
      By arefiev.dm
      Hello! I put P222 on my Gen8 server, but I can not use RAID6. Can someone share the key?
