HTPC HW and SW advice
Server Grunt
I am about 90% sure that cablecard, and thus ceton and hd homerun, are US only. It seems I have heard Ian Dixon say this.
I was thinking it's relevant because Server Grunt says he's in Europe.
    • E3000
      By E3000
    • Sokoban
      By Sokoban
      Hi
      My HP Proliant Microserver Gen 8 won't install HP Tools when I have running HP Smart Update Manager.
      even when I have trying to install via Intelligent Provising, Windows Server 2019.
      Se image below 🙂 That's I missing.. ;-(
    • Dave
    • Dave
      By Dave
      The SDM R4 is SOLD OUT!
      The SDM R4 is a bracket that facilitates mounting two additional 2.5″ drives in a HP MicroServer Gen8. There are also mounting holes for fans across the bottom to help cool RAID/SATA cards. The kit includes all the fasteners needed to install.
      With optional Stackers you can run four 2.5″ drives on the SDM R4. The SDM R4 will support four 9.5MM 2.5″ drives. If you want to run four drives on the SDM R4, you need to order SSB stacking brackets listed below. One set of SSB per drive pair, four drives will require two SSB kits. Because of the size of the SDM R4, if you are going to boot your server using the internal USB port, you will need to use a USB stick that is shorter than 1″. For more information on mounting instructions look here: http://homeservershow.com/forums/index.php?/topic/5960-hp-ms-g8-25-drive-bracket-revision-history-new-rev-35-and-rev-4-info/?p=137922
      The SDM R3.5 is in stock and ready to ship!
      The SDM R3.5 is a bracket that facilitates mounting one additional 2.5″ drive in a HP MicroServer Gen8. The kit includes all the fasteners needed to install.
      With optional Stackers you can run two 2.5″ drives on the SDM R3.5. The SDM R3.5 will support two 9.5MM 2.5″ drives. If you want to run two drives on the SDM R3.5, you need to order SSB stacking brackets listed below. One set of SSB per drive pair. For more information on mounting instructions look here:  http://homeservershow.com/forums/index.php?/topic/5960-hp-ms-g8-25-drive-bracket-revision-history-new-rev-35-and-rev-4-info/?p=137922
      SSB-9.5 for 9.5mm drives $10
      Schoondoggy Stacking Brackets can be used to stack two 2.5” drives. All screws are included
      SSB-7 for 7mm drives $10
      SOC-MSG8-R1 kit for 9.5mm optical drives to latch it in place. Screws included $9.
    • pzjuls
      By pzjuls
      Hi everyone my first post,
      Haven't built a new HTPC in 10 years here is my list we have just built a new house and i have a 90u rack in the utility room.
      I intend to use the rig to play Kodi on the main living room big screen linked via HDMI look after the 5 security cameras with blue iris and use windows 10 storage spaces to pool 4 x 3 terabyte drives and do some and bitcoin mining.
      Intel Core I5-7500
      Gigabyte Intel GA-H270-HD3 LGA 1151 ATX Motherboard
      HyperX 8GB (2x4GB) 2400MHz DDR4 Non-ECC CL15 1.2V Memory
      Gigabyte GeForce GTX 1070 WINDFORCE OC (8GB) Graphics Card PCI Express 3.0
      alos need a case i have been looking at these 2
      https://www.xcase.co.uk/products/x-case-x445-c4-lcd-4u-with-4-hotswap-bay?variant=10286623109
      http://www.silverstonetek.com/product.php?pid=331
      anyone got any thoughts on this?
