Review of SilverStone TJ08-E Micro-ATX Chassis
diehard
I sure like the two SG05 I have. This one looks very appealing to me as I happen to be in the market for a smaller tower to replace an old cooler master case. Thanks for the link John.
There is a new PQ-25 model on Lilian Li web site supporting up to 7 3.5 IN drives. Suggested prise is 149 USD.
We are getting more and more options to chose from...
Edited by Hardened
It even has a "removieable hard drive rrak"! I'm not sure what a rrak is, but anything removie-able should be good for a WHS, right?
Guest no-control
This would make for a sweet gaming rig. Not sure on the review though they make it sound like the reverse mobo idea was some new out of the box idea. Lian Li has been doing it for years. I wouldn't use it for a storage server though. Better cases out there for the money (fractal?)
@Timekills - rrak is obviously misspelled to do the trouble some Asian dialects have with English (engrish?) Obviously they meant Iraq...and anytime you can remove Iraq from the case its a good thing.
:lol:
Edited by no-control
I looked at the PQ-25 for my new desktop, but I just couldn't find a mini-ITX mobo with the features I wanted so I had to go with a micro-ATX instead. I wish mini-ITX boards had more connectors. Oh well, I can dream, can't I ??
    • cakthy
      By cakthy
      I have a Raidmax case that I suspect is messing with my motherboard, and I generally don't care for the large size of it. So I will be selling the case if I can find a new one.
      What I need:
      Something $70 or less (I could go more if needed)
      Black color
      Side window
      Micro ATX size
      Handle/possible to mod for a handle
      I was looking at this one: E-2007 to buy. So what do you think? Any cases that you know of that I could buy?
    • sleepkitty
      By sleepkitty
      Before some many choices of case that I had, I've finally decided to go with the PC-T3-i5-4200U, but the official website does not give too much info about this beautiful case.
      http://www.minicase.net/minipc-i5-4200U-T3.html
      So, if there is out there any PC-T3-i5-4200U owner that is reading this topic, I've a few questions for you friend, and I'll really appreciate any answer that could be provided.
      These are my questions:
      How many space for rad (or fans only) I will have in the space behind the case?
      How much thick my rad in the top can be with fans without touching the fans at the front? (The ones that are perpendicular with the Motherboard).
      How much tall can my Reservoir be with Pump included? I don't wanna drill holes in such a beautiful case.
      As I said, any info provided would be really appreciated!
    • ckqualls
      By ckqualls
      I'm in a choir which is stuck on paper, and we have to use 3 ring binders for uniformity.  I was hoping to find an insert that fits into a standard 3 ring binder that holds a Surface Pro 3. I've scanned the music into OneNote.
      Thanks,
      Kelly
    • gadgetek
      By gadgetek
      Hello!  I have created a tablet case for the Surface Pro 3 which is designed with artists in mind.  I launched a campaign on Kickstarter to raise funds to produce it.  It is not just a protective case, but a protective case that brings functionality for those time when you don't want the keyboard, but want easy access to keyboard shortcut.  I've integrated buttons into the case that can be customized to your favorite shortcuts in any program.  Please take a look!
      https://www.kickstarter.com/projects/gadgetek/meta-the-microcontroller-enhanced-tablet-accessory
    • kristikay
      By kristikay
      I do a lot of off table work on my Surface Pro 2, and I miss the 'fixed' hinge on a laptop that keeps the keyboard and surface at a consistent angle.  Has anyone seen a hardshell case or other type of solution for this?
