WHS build - problem? No hibernating?
James Walker
Hello Forum;
I hope someone can help me resolve a delema I have.
I just recently upgrade my orginal WHS v1, build 0.0 (a IBM netvista PC) to a new build WHS v1 build 1.0. I used an Asus M2N-SLi Deluxe motherboard I had with 1 Gig of ram. Everything installed as it should. I had use ligths-out in my prvious build and wanted to use it with this build however, when I went to setup lights-out to control when the server would run and not run I noticed that I did not have the option to use hibernation. lights-out indicated it was not supprted?? I checked and the Asus MB does have support ACPi and it is enabled. what did I miss in my installation that cold allow this feature to be used?
Thank you
Guest no-control
Is hibernation enabled in the OS?
open a CMD prompt
-> powercfg /hibernate on
-> Press Enter
See if that works
