LSI 9260-4i Ups and Downs
Greg Welch
I'm with you re: the HighPoint. Nothing against them, but they're what I call Host Bus Adapters rather than full RAID cards. For me, a true RAID card has to do all the processing on board, and have it's own memory for all data transactions. LSI is, AFAIK, still a good brand of these.
Oh the one BIG set back to the LSI card (and this mght be for all Processor on board cards) is the my POST times are very long now, it add at least 20 to 30 seconds to startup.
Cooper
Cooper
True, depending on the make/model of card the start times will increase by xx seconds, but unavoidable since they do have to load their own 'OS' as it were. Still, the benefit of increased performance from offloading the rest of the system makes it worth IMHO. The biggest downside I feel is the $$$. Full RAID cards ain't cheap baby! :P
You can offset that by disabling the card's ability to be bootable. You might (unfortunately) also have to set the onboard ports to RAID, even if you don't use them that way, but the onboard RAID BIOS checks are much, much faster than the add-on card's checks. If you disable the card's ability to boot, it won't go through the check during POST.
I could tell you how to do it with a lowly HBA-type adapter like the Highpoints ;) but you're on your own with the LSI's.
Would be interesting to see how much time that can shave off.
Can't do that, as I am booting from the card, the RAID Ø is my OS drive I have a 2TB WD Black for the data drive
  • 4 months later...
The Dell PERC H700 controller has a feature called “Cut-through IO (CTIO)” that should supposedly increase the throughput for SSD drive arrays.
I believe the Dell is similar to the LSI. (I have a Dell 700 but no SSD)
As per the documentation it says its enabled on an LD (logical drive) by disabling read ahead and enabling write through cache (WT + NORA).
You should see a perfromance increase on a SSD drive.
here are a couple of links
http://sqlblog.com/blogs/joe_chang/archive/2010/10/11/caching-raid-controller-performance-tuning-secrets-cough-giggle.aspx
http://marcitland.blogspot.com/2011/03/accelerating-vdi-using-scst-and-ssds.html
    • Giuseppolino87
      By Giuseppolino87
      Hi everyone, today I wanted to install esxi 6.7 to try out the various functions, my question is the following, I have a server where I have installed esxi in an SSD and I have two other 4 tb disks so 8 tb total.  I would like to make sure that when I create a virtual machine in this case I will install the various virtual machines in the SSD and use the two disks for data.  So how can I do this?  Thank you very much for those who can help me.
    • E3000
      By E3000
      Looking for a quick answer here from someone in the know...
      I upgraded some of the internals of my Gen8 server and at the same time I did a BIOS reset as I had forgotten the password that I had set years ago. When booting back up the upgraded hardware was detected and fine but I received Error 1784 - Drive Array - Logical Drive Failure. I believe this is due to a setting change in the BIOS and not anything hardware related. I have gone into IP/SSA and see the array needs to be rebuilt. I had all drives configured as single RAID0. It says all data will be lost if I reconfigure this but I remember reading somewhere on here that the data will be fine if I reconfigure as RAID0.
      I do have a backup of course, but it’s not a high availability mirror and will take some time to get back the way I had it, so just want to know if it’s safe to reconfigure the RAID0 without erasing the drives. I have tried pulling the drives out and connecting them to another PC and they are fine. Can anyone tell me which options to choose to get these back to normal and remove the flashing red light?
      Thanks 😶
    • Mark Belanger
      By Mark Belanger
      Greetings,
      I'm new to the HPMSG8 world and so far I'm loving it. I have a stock Xeon with 16G of aftermarket memory with iLO patched to 2.70. Next up is adding a RAID card, so I can put my boot SSD on the onboard RAID. I picked up a LSI SAS9211-8i on Amazon, but am struggling to flash it to IT mode on the MicroServer. Is this even possible? Unfortunately, the only other system I have with PCI slots is 32-bit.
      Any pointers would be greatly appreciated.
      -MB
    • TakiBot
      By TakiBot
      I've got my hands on a HP N40L.
      Can i use raid 1+0 on my 4 2TB WD RED or only 1 and 0.
      Thanks for the help.
    • arefiev.dm
      By arefiev.dm
      Hello! I put P222 on my Gen8 server, but I can not use RAID6. Can someone share the key?
