Missing Drive V1
jazzerjay
Last night after my weekly Server backup I received an error stating that I had a missing drive. Sure enough the drive light was off. I removed and re-seated the drive and all appeared fine this morning. Do you guys think I dodged a bullet or am I playing with the inevitable dying hard drive? Also, I just read the post from MNSearcher about duplication, but I didn't experience any other issues and yes this is the first time I've had this issue.
My EX485 has three 2TB WD EADS and one 1TB Seagate for OS.
Impossible to tell especially if you have add ins. I would certainly keep an eye on it. You can also download and install an add in to view the smart data and to see if there have been issues with the device itself. I have had the same thing happen to me in the past and it turned out to be a cable.
Thanks guys, I will do so once I get home. Too bad I needed to work today.
Gotta pay for our toys somehow.
@JediTim - True dat
I actually have the SMART add-in installed. All four drives show zero errors. I'm half temped to start the removal process, better safe than sorry I suppose. The challenge, of course, is the length of time it takes to move data off of the drive. What's a terabyte between friends? More on this later.
Jay
@JediTim - True dat
Jay
When this happens to me I Remove the drive, replace with a spare, and Spinrite the suspect drive on level 4. If it passes, it goes back on the shelf as a spare (properly labelled of course).
A level 4 on a 2TB drive will take some time. I just started a level 1 and estimated time to completion is 10 hours. I can certainly pick up another drive. I placed my other drive specs in the original post. I was looking for an EADS, but those are very expensive or I at the very least from questionable sources. Any suggestions on another drive and I would be extremely grateful.
Jay
Jay
It does take a long time; that's why I have another spare drive to swap in. That way, it doesn't really matter that it takes a while, since everything is running properly.
