Upgrading to a 16 port Switch need recomendations
TSWired
I have been getting by with an 8 port switch in my home network and I am getting ready to add at least two ports for HD Home Run tunners so it is finally time to upgrade.
I plan to do streaming of Blu-Rays from a WHS to HTPCs (possibly two at one time) gaming on PS3s over the network and regular basic internet stuff.
I know I want Gigabit and will need at least 12 ports so I am looking at the 16 port switches to leave some headroom.
So far this is my first choice:
NETGEAR ProSafe GS116 Gigabit Desktop Switch with Jumbo Frame Support 10/100/1000Mbps 16 x RJ45 512 Kbytes per port Buffer Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16833122139
I know in the past this router had some power brick issues, so any suggestions/recomendations. I am not too worried about the power adapter issues, as I am guessingit may have been updated by now and is fairly cheap to replace.
I have been using a similar Netgear 16 port switch for about 18 months and have had no problems with it.
I have the 8 port version of the netgear for the past year and it has had zero problems. I bought the 24 port version of the netgear for our lawfirm and it has had zeros problems as well.
I have been using that 16 port switch listed above for a few months with uverse and have had zero issues. No reboots or anything needed.
Ive been using the Dlink 24port mentioned above for a couple of years and I couldn't be happier.
Edited by tojoski
Stick with the name brands as mentioned above and you will be good. That 24 port DLink is an awesome buy.
Decided on the 24 port D-Link, based on price and having lots of future expandability if I ever need it.
Thanks for all the recomendations
