Sabertooth Mem Issues
ZA_Tigger
Hi Guys,
Anyone have a problem with their Sabertooth p67 board where you can only have memory in slot 3&4. I have 2 Corsair 4GB Vengeance Modules and they only work in those 2 slots. Even if I just use one it has to be in those 2 slots. So now dual channel isn't possible.
The funny thing is I came across the exact same problem in this thread http://www.boards.ie/vbulletin/showthread.php?t=2056234599 the guy has the same configuration and memory and exactly the same results?
Seems really odd any ideas? I am on the latest 1850 bios
Cheers
Andrew
Guest no-control
I don't have any issues with my Sabertooth. I'm also not using corsair memory, I have G.Skill and it runs without issue. I know Doc had issues with his Vengeance memory and dumped it. So I would lean towards its a memory issue rather than a mobo issue.
maybe it's one of those issues from the past where it's the combo of the mobo and the memory. I thought those issues were behind us but maybe this is a modern instance of it.
No RAM/MOBO compatibility is still an issue, just less common.
seems so. Too bad too in this case; I'm a huge fan of Corsair memory; it's always been great for me.
Guest no-control
Seems its just the vengeance line. I haven't run across a lot of complaints about the XMS or Dominator lines. It is a new line so perhaps they still haven't worked out all the kinks yet.
Hi Guys,
Cheers
Andrew
no-control is correct and I have had issues with the Vengeance. I also was able to run all 4 banks with Gskill and no issues. Are you running the memory at 1600? Did you use he XMP profile or hand tune? The sabertooth has strange memory setting so I would try defaults first to see if runs stable. Before you RMA the board, I would try a different brand of RAM, use the GSkill. I agree with no-control, seems more like memory.
  • 4 weeks later...
Hi
Just to keep you in the loop, I went and bought Kingston Hyper X memory that was on the compatibility list. The board still didn't work so back she goes....
Unfortunately in South Africa I have to wait a week for the swap out so I am pc less but luckily I have my new WHS2011 issues to keep me busy and drive me nuts :-)
Cheers and thanks for all the advice
Andrew
