Protocol versions don't match
IsYet
I get the following error (found in the laptop event log) when I try to connect from one laptop to my WHS.
Event:
This computer uses protocol version 6.0.3436.0, but partner computer MCKWHS uses protocol version 6.0.2423.0. A connection cannot be established.
No connection method works - web browser, file explorer, WHS Console.
My WHS is an HP EX-495.
WHS Version 1.
Laptop is Windows 7 Professional. Up to date with system updates.
Connections from other PCs work ok.
Backups do work on the affected laptop.
This laptop used to work fine.
My troubles began when I let the battery on the machine completely run down. A power strip switch was turned off.
I had major problems after getting the system running again. It would lock up, no screen but a lot of disk and CPU activity (the fan was running hard). The only way to stop it was to turn it off at the switch.
I was able to narrow the issue down to the connector.
Uninstalled and re-installed the connector from the WHS software folder (copied to a USB stick).
The lockups went away but still won't connect.
Event:
WHS Version 1.
Have you tried uninstalling the connector from the client PC and then re-installing it from http://mckwhs:55000, or can you not even browse to that page? I know I found that it's easy to get the wrong verisino of the connector if you don't use the web page. I believe Diehard knows where the one used on the web page is stored on the WHS. I do know it's stored on the C: drive, not in the shared Software folder on D:
I'll give that a shot.
Thanks.
