OS and Pictures on same Mirror?
vinylfreak
I am in the planning stages of my upgrade from WHS ver. 1 to WHS 2011.
Question??
I was planning on using the IcyDock enclosure to Mirror two WD Black 500gb laptop drives for my OS.
Since 500gb is overkill just for the OS, I also wanted to store my Picture files on the same Mirror with the OS.
Is there a downside to this strategy?
If so , what would it be??
Thanks Tim
The only downside I can think of is that it would make your OS drive used (read and write) more than if it was just the OS. Outside of that, none I can think of. I have the same setup but will only use the mirror for the OS.
Create another partition on that volume (shrink the C) and put your photos on that volume. Just move the folder via the wizard.
Question??
Thanks Tim
Technically there is nothing wrong but personally I would not do it. Having blown away my WHS install several times, I want that primary drive free and clear of data. Just my two cents.
