Finally able to restore my EX490
Don W
Has anyone else had trouble restoring their HP Mediasmart Server? I tried a dozen different times to restore my Mediasmart to factory defaults because I sold it and it always got stuck at step 3. After searching through everyones forums (HP Forums were not helpfull at all) I finally found a post that said to put my computer in Safe Mode and try it from there and it worked on the first try. What a relief. Has anyone else had this trouble or does it work without putting your PC in Safe Mode. HP should at least mention that if you are having problems to put it in Safe Mode.
I had an issue with a motherboard's ethernet card. It didn't like it for some reason. Changed to a cheapo laptop and it ran fine. It's a bit picky with some lan cards. Good tip on the safe mode.
