Recommended hardware forum
Don W
As you wish.....
Recommended WHS Hardware
CPU - intel core i3-530 or i3-2100
MOBO - any H55 or H61, H67 that meets your needs. Asus and Gigabyte are BYOB's top picks
RAM - 2-4GB DDR3 1066 or 1333
PSU - Corsair or Coolermaster, anything with the power you need and has good reviews on the net.
HDD - Western Digital
SSD - OCZ vertex
Full tower case - Lian Li A71F
Mid tower case - Corsair 650D
Mini tower case - Lian Li V354
SFF case - Lian Li Q08 or Silverstone SUGO5
OEM boxes
HP Proliant Microserver
I'll pin this until the forum changes take effect
Is there a way that we can start a forum post and make it sticky that has subsections for recommended parts for building home servers. When I am building home servers for people I am always thinking to my self "What is the best case I should get", or "which motherboard/CPU combo should I get" and it would be nice if I could just come to the forums and the first topic would be sticky would be Recommended Hardware so it could be something like...
* WHS Builders Forum
* Recommended Hardware
* Cases
* Motherboards
* Powersupplies
And then people could add hardware they found that others could look at that they might want.
Don
silly me, I always went to the WHS builders forum and never looked at the hardware forum, I guess you already had subjects like I described, although I thought it would have been under the builders forum.
Edited by no-control
Serving the people
  • Replies 28
  • ImTheTypeOfGuy
    4
  • timekills
    3
  • Joe_Miner
    5
My fault on this one. I have an outline of the new forums layout and have yet to find the time to implement it. It will separate v1 from 2011 and create a little more organization around here. Sometime soon, i promise!
ASUS doesn't like installing drivers on Windows Server operating systems. I'd go with MSI instead.
I read your other post on this, and at risk of sounding flippant, I'm not sure I agree with this comment. I have two Asus boards running WHSV1 and 2K8R2. Both had zero issue with driver install. Both are last-gen (1156) however, if that makes a difference.
My 1155 Asus Sabertooth had issues. Nothing I am worried about, but it had issues. Didn't want to load chipset or audio drivers.
The Asus P8P67 Pro won't install onboard NIC drivers. :(
For PSU, I'd recommend nothing but Seasonic. In all the (~100) systems I've built using them, not a single one has caused problems...ever. I'm sure the others are good also, but Seasonic gets my vote every time.
Guest no-control
uhhhhh.....PICNIC?
I haven't had issues with drivers from Asus boards with my servers. What server OS and what driver on what board and what NIC? I would still take a gigabyte over an MSI. I have 2 MSI boards in front of me for new builds and while I have nothing negative to say (yet) I'm not impressed either.
uhhhhh.....PICNIC?
Heh. PEBCAK.
Guest no-control
Heh. PEBCAK.
RTFM
PIBCAK
ID:10T Error code
TSTO
RTFM
Mode error
It's a layer 8 issue
Sir is the service tag read one delta ten tango?
I have several of them, help desk yay!
