Audio track selection question
krom
Okay guys I have a question about how to select an alternate audio track in MCE. I have some MKV's that have multiple (well, two) language tracks and I want the second one. This is on problem in say VLC but I get into the MCE interface and all I get is the default audio track, which is the wrong one for me. If it's possible I know you guys will now how. Thanks.
Do you want to change which track is the default, or be able to change the track within the MCE interface?
Thanks AJ that worked perfectly. BTW if you do want to pick your audio stream in MCE looks like this article in www.hack7mc.com will help with that. http://www.hack7mc.com/2009/06/advanced-codec-support-inside-media-center-with-media-control.html . It was actually referenced in the post listed above so thanks again AJ looks like you found the answer to both methods.
