Cannot restore from HP Help!
CablDeViL
At work I have a HP data vault. I have a win7 x64 laptop that needs to be restored. I load up the restore cd and toss in my usb drive with the correct 32 bit drivers for the network card. But it refuses to find the server. Even if I put in the server name manually it says that "The Wizard cannot find your Home Server".
Any help with this problem. This is the first time I have used a HP WHS to do a restore.
Update: Looks like I did not load up the drivers since my router port is dark. Dam they are the correct drivers.
Solved: Bad cat 6
yes I could from the other clients. I did find the problem the realtek vista 32 driver from their site didn't work but the driver from the toshiba side did. "Interesting"
All better now.
