itm Posted March 15 Share Posted March 15 I've installed ESXi 6.7.0 from a HPE Custom Image. It is booting from an internal MicroSD card in the Microserver. While I see a USB controller in the device list in ESXi, it is not showing either of the two external USB hard drives which I have plugged into the ports at the back of the Microserver. The ESXi hardware list showed two USB controllers. I have toggled passthrough on both and rebooted - they are now showing as "Active" in the Passthrough column. Any idea how I can get ESXi to recognise these drives? Link to comment Share on other sites More sharing options...
itm Posted March 15 Author Share Posted March 15 It seems that the USB drives are being detected at some level, as I can add them to guest VMs as USB devices if I edit their settings. They are not detected as disks by the guest VMs though. ??? Link to comment Share on other sites More sharing options...
Trig0r Posted March 15 Share Posted March 15 Have you assigned the USB controllers to the VM you are using, its been a while since I've played with esxi so can't remember the exact route for this.. Link to comment Share on other sites More sharing options...
itm Posted March 15 Author Share Posted March 15 Yes the VM has a USB (2.0) controller assigned to it. Link to comment Share on other sites More sharing options...
itm Posted March 15 Author Share Posted March 15 So I managed to resolve the problem by removing the USB 2.0 controller which has already been assigned to the VM, adding a new USB 3.0 controller, and re-adding the external drives as USB devices. The VMs now see them as disk drives. I have no idea why the USB 2.0 controller had problems. 1 Link to comment Share on other sites More sharing options...
