juan9999 Posted March 9 Share Posted March 9 I'm setting up a HP Microserver Gen 8 as a backup NAS. Server hasn't been used in a while so I upgraded it to to iLO Firmware Version 2.78, I noticed this error: Controller firmware revision 2.10.00 NAND read failure: Media is in a WRITE-PROTECTED state After some research I found this: https://support.hpe.com/hpesc/public/docDisplay?docId=a00048622en_us Basically, it says to format the NAND. I tried to do it within ILO (Option 1) but I don't have the format option as in the screenshot. So I tried option 3- From Windows OS (using the HPQLOCFG.exe utility but I got the following error Quote CPQLOCFG.exe: ERROR: Malformed RIB response: (30): HTTP/1.1 501 Not Implemented CPQLOCFG.exe: Script succeeded on "192.168.200.21:443" Also tried a reset within ILO. Has anyone reformatted it successfully? What issues am I likely to run into? I intend to use my SD slot to boot ESXi Link to comment Share on other sites More sharing options...
juan9999 Posted March 10 Author Share Posted March 10 UPDATE: found the format option, I had to press iLO Health twice. Unfortunately, formatting the NAND and resetting 4 times with unplugging for a minutes in between didn't work for me. I also tried upgrading/downgrading ILO firmware versions and that didn't work. Link to comment Share on other sites More sharing options...
E3000 Posted March 10 Share Posted March 10 It seems a lot of people are getting this error recently, is there a reason why? Link to comment Share on other sites More sharing options...
langers2k Posted March 11 Share Posted March 11 I think earlier ILO firmware versions had an issue causing excessive writes to the NAND. This can wear the NAND out with the only 'option' being to replace the system board. https://support.hpe.com/hpesc/public/docDisplay?docId=emr_na-c04996097 1 Link to comment Share on other sites More sharing options...
E3000 Posted March 12 Share Posted March 12 23 hours ago, langers2k said: I think earlier ILO firmware versions had an issue causing excessive writes to the NAND. This can wear the NAND out with the only 'option' being to replace the system board. https://support.hpe.com/hpesc/public/docDisplay?docId=emr_na-c04996097 That seems quite a few versions ago but makes sense as many never update these things… Link to comment Share on other sites More sharing options...
