altiport Posted March 5 Share Posted March 5 I plugged a new network card (HP I210-T1) on the PCIe x16 slot. It is a PCE 1x card, but it should work, shouldn't it? Well, it is not recognised at all. The system is running Ubuntu Server 16.04. I followed Intel's guide to install a driver, but to no avail. The card does not appear in ifconfig or lspci Any suggestions are welcome Thanks Link to comment Share on other sites More sharing options...
schoondoggy Posted March 6 Share Posted March 6 Have you tried the card in a different system to confirm it is working or connect a network cable to a switch to see if you get link lights on the card? Link to comment Share on other sites More sharing options...
altiport Posted March 20 Author Share Posted March 20 Followed your advice and the card turned out faulty. Replacement NIC works fine on PCIe x16 slot. Thanks 1 Link to comment Share on other sites More sharing options...
