azho Posted January 23 Share Posted January 23 Hi All I'm completely stuck with new drives. I've bought P222/512 SAS controller (firmware 8.32) and bunch of HP disks SMEG2000S5xnF7.2 (rebranded seagate ST2000NM0063). My controller in RAID mode kind of see these disks but none of them are "compatible". HPSAA reporting that these disks does not support RAID. General alert: 267 - There are no configurable physical drives attached to the current array controller. I've found instruction how to switch P222 into HBA mode and did it, now I can see drives as is, but all operations with them are causing IO error. I suspect it might be connected to SED (Self-Encryption Disk) feature but I have no idea how to turn it off to have normal storage. Have someone faced with such disks and what would you suggest to do to resolve this issue? Link to comment Share on other sites More sharing options...
gibster Posted January 24 Share Posted January 24 It's been a long time since I had my HP server and P222 card. I don't know if your just trying to get your server setup for the first time but this link will hopefully help you get going. http://h10032.www1.hp.com/ctg/Manual/c02289065.pdf Cheers Gib Link to comment Share on other sites More sharing options...
azho Posted January 25 Author Share Posted January 25 Looks like an issue was with drives, as they were formatted with 520 block size rather than 512, I haven't looked at block size and contacted seller about the issue. So Self-Encrypting Drive (SED) feature of the drives was not involved into the issue. So I've reformatted them (it took about 12 hours for 2Tb) and they are visible to controller now. Btw, to reformat them: I have switched P222 to HBA mode (P222 how to switch hba mode) booted from Linux and used sg3-utils for format all disks in parallel (Enterprise HDD with SAS controller) After formatting with 512 block size, I switched controller back to RAID mode, and P222 was able to operate with these disks. 1 1 Link to comment Share on other sites More sharing options...
