Same power consumption after mounting CPU 1220LV2
lluisd
I had a Celeron G1610T with x4 WD blue 7200 1TB disks and 8gb ram. The power consumption in idle was 43-45W.
I upgraded the CPU and now I have a xeon e3-1220LV2, the power consumption is still exactly the same in idle state. I removed all 4 disks and downs to 26W.
But I don't undrestand why they said that 1220LV2 has a TDP of 17 Watts and G1610T 35 Watts if in practise is the same in idle state.
TDP means Thermal Design Power, so how much heat is generated, not how much power it uses.
For instance, the stock CPU cooler is rated to 35w I think it is, yet uses no power at all, so why would it be rated 35w?
Understand?
