jeremy_fritz Posted November 29, 2020 Share Posted November 29, 2020 Hi! I am currently using ESXi on my HP Microserver Gen8. I would like to migrate from ESXi to Proxmox. I've been told that there are some compatibility issues between Proxmox and HP Microserver Gen8 (especially about the fan, which always runs at 100%). Do you know if there are still these issues? Do you know if there is a tutorial or a guide to install Proxmox on HP Microserver Gen8? Thank you so much! Jeremy Link to comment Share on other sites More sharing options...
E3000 Posted December 5, 2020 Share Posted December 5, 2020 On 11/29/2020 at 9:44 AM, jeremy_fritz said: Hi! I am currently using ESXi on my HP Microserver Gen8. I would like to migrate from ESXi to Proxmox. I've been told that there are some compatibility issues between Proxmox and HP Microserver Gen8 (especially about the fan, which always runs at 100%). Do you know if there are still these issues? Do you know if there is a tutorial or a guide to install Proxmox on HP Microserver Gen8? Thank you so much! Jeremy You can install it the same way as ESXi and that issue with the fan at 100% is not true. In general any Linux system seems to run the fans higher speed than Windows, but that’s down to installing the software (which not all are available to Linux). Also it depends whether you are using B120i or AHCI. Link to comment Share on other sites More sharing options...
