Problem with Bluescreen!
Similar Content
By hhvdwatt
Hi I am new to forum.
I have an HPE 40L Microserver and would like to upgrade the motherboard to something a bit more modern.
From what is can find on this topic it would appear that the motherboard is mini-ITX like but not exactly. Has anyone ever resolved upgrading this with something new that works or should I just replace the server?
Thx in advance
By E3000
Hey guys,
Bit of a random question here, and I know it depends on many factors such as what they are doing etc, but how many VMs have you guys comfortably ran on Gen8 with an E3-1265v2 and 16GB RAM? When did you start to see a performance hit compared to what the Gen8 is generally capable of?
By dxzdxz1
This is my first post here but I've been lurking in this forum for quite sometime now, and from what I understand, the only reason that we couldn't achieve 32gb ram on the Microserver Gen8 was because there was no 16gb unbuffered ecc ram available before.
I was searching for a memory module meeting this criteria and I found this one. My question is, letting aside this ridiculous price, is there any compatibility issue that could make this ram won't work on the Microserver Gen8?
Most of the threads here about memory compatibility are quite old and I didn't want to revive an old thread just to ask this, so I'm creating this one.
Thanks in advance.
By AllanHP
Hello guys, i have a HP ProLiant ml350p g8 I had installed one gpu card rx580 strix and I had used one gpu frequency management call asus gpu tweakll, when I change gaming mode to silence mode my computer restart and I saw one red light on the motherboard, I fix the problem I had installed one old version of the asus tweakll, now the computer works well, but the red light still on, I used the software OCCT I checked psu memory gpu voltages run many testes and pass in all tests, I try to find in the manual what this red light is but I can't find, thanks for the help.
By Orion
I am building a Ryzen machine. Using the new Ryzen 7. What is the best ram to use. Obviously ddr4. And recommendations on brand and size
