GarethC 29 Posted August 23, 2020 Share Posted August 23, 2020 Hi All, I've got a HP Elite Desk Mini which has a Samsung 970 EVO Plus 250GB NVMe & a Samsung 970 EVO Plus 1TB NVMe, both of these drives are overkill for the machine (it really only needs a 120GB drive for the OS as all storage is stored on the server anyway) but in a previous life it was used as a CCTV machine. Its occurred to me that these drives could be better put to use in the PCI-E slot of my Gen10 Plus (250GB OS, 1TB for VMs) if indeed that is possible. I don't understand this whole bifurcation thing though, baring in mind I'm in the UK, would anyone be able to point me in the right direction of if this is possible and what card I would need to be looking at? Thanks in advance, Gareth Link to post Share on other sites
GarethC 29 Posted August 23, 2020 Author Share Posted August 23, 2020 I think this is what I need, but not sure if I'm going to be pushing my luck power wise running this with an E2246G, 64GB, 2 x 6TB HDDs, 2 x SATA SSDs, TPM & ilO Enablement. https://www.ebay.co.uk/itm/Lycom-DT-130-Dual-PCIe-NVMe-M-2-SSD-Carrier-Adapter/303635103878?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649 Link to post Share on other sites
schoondoggy 895 Posted August 23, 2020 Share Posted August 23, 2020 That card is sold be several vendors, Startech, Ablecom, Addonics and Lycom. The specs show it has a PCIe switching chip on it, so you should not need to do anything with bifurcation. I have not seen anyone test the card in a Gen10 Plus yet. They were discussed here: Link to post Share on other sites
GarethC 29 Posted August 23, 2020 Author Share Posted August 23, 2020 Yes it seems to be a suitable fit, its just a question of whether i’ll pushing the power cap with everything else in the system or not. Link to post Share on other sites
GarethC 29 Posted August 24, 2020 Author Share Posted August 24, 2020 I'm going to see if I can accurately measure the power consumption of the server under load and will go from there, but in an ideal world i'd like to add the Lycom and the two NVMe drives. Link to post Share on other sites
