Led Disk not working correctly?
thiagotgc
I'm using my Gen 8 with 4 disks, on VMWare ESXi 6.5 with the latest updates.
When I create drives together or separately in RAID 0, the disk usage indicator led works perfectly.
But, when I create RAID 1 drives, the disk utilization indicator light is on.
Has anyone noticed this? Have a solution?
Sorry, I don't have a Gen 8. But when you say "the disk usage indicator led works perfectly", do you mean to say that it blinks when there's activity?
HP's documentation is a little vague on that one too:
Drive status LED:
  • Solid green = System on
  • Flashing green = Drive activity
  • Off = System in standby or no power present
So that can be "normal" under the first bullet. But it doesn't satisfy the 2nd bullet, as per your observation.
Edited by oj88
@oj88
It should only flash when in use.
But with RAID1, it doesn't flash, it gets direct access ...
This is bad, because I can't know when the discs are being used ...
