demiurg 0 Posted May 24, 2020 Share Posted May 24, 2020 Does anyone already have some experience with a non-standard CPU? https://www.servethehome.com/hpe-proliant-microserver-gen10-plus-ultimate-customization-guide/2/ E.g. Xeon E-2236 Link to post Share on other sites
Jason 84 Posted May 28, 2020 Share Posted May 28, 2020 Really hoped this box supported Intel QuickSync on CPU. Seems like a miss. Link to post Share on other sites
doudoufr 0 Posted June 4, 2020 Share Posted June 4, 2020 i installed a core I5 8400 and it works :-) Link to post Share on other sites
Jason 84 Posted June 4, 2020 Share Posted June 4, 2020 HP indicated a Xeon with QuickSync support wouldn’t work on the G10+. Not a big deal. Just started setting mine up. Added a PCIe NVMe card to boot from M.2 NVMe drive. Installing WS2019 Std. Just not a VMWare ESXi fan. Link to post Share on other sites
Trig0r 211 Posted June 4, 2020 Share Posted June 4, 2020 Pretty sure QuickSync and stuff like that is unlikely to be supported in a server type device, regardless of what CPU you put in there.. Link to post Share on other sites
GarethC 29 Posted August 24, 2020 Share Posted August 24, 2020 E-2246G works amazingly, I thought the E3-1230v2 I had in my Gen8 was impressive, but this is a definite step up. Link to post Share on other sites
Jason 84 Posted August 24, 2020 Share Posted August 24, 2020 Do you have to reinstall the OS after a CPU swap? Or is it seamlessly detected? Link to post Share on other sites
GarethC 29 Posted August 24, 2020 Share Posted August 24, 2020 (edited) I installed the CPU prior to installing the OS, i'm pretty sure it would be seemless though. Edited August 24, 2020 by GarethC 1 Link to post Share on other sites
Jason 84 Posted August 24, 2020 Share Posted August 24, 2020 I installed the CPU prior to installing the OS, i'm pretty sure it would be seemless though. GarethC, are you finding that CPU support Intel QuickSync hardware acceleration when added to the Gen10 Plus? Link to post Share on other sites
Jason 84 Posted August 25, 2020 Share Posted August 25, 2020 Oops. Nevermind. Intel QuickSync won’t work in Gen10 Plus even with an E-2246G CPU.https://community.hpe.com/t5/proliant-servers-netservers/microserver-gen10-plus-and-intel-quick-sync/td-p/7084407/page/4 Link to post Share on other sites
