N40L-LSI Megaraid SAS 9260-8i - Problem with webbios
danielpfi
Hello,
II added LSI Megaraid SAS 9260-8i controller cards on the N40L server
I tried to enter into configuration mode (WebBIOS) by press CTRL+H. Nothing happens.
the system continues to access the next drive in line for bootup order.
Not sure if it will work here, but sometimes if you enter the boot menu during boot, select the drive you normal boot from, then continue the boot process you will be able to enter the LSI BIOS. Sorry, I do not recall the keystroke to enter the boot menu.
I solved my problem.
With the megaclid command (ctrl+y), i created a raid volume, and i installed the OS with a bootable usb.
I was able to select the volume raid during the installation.
The bios boots on the raid voume of the raid controller LSI
I tried to enter into configuration mode (WebBIOS) by press CTRL+H it's ok. 🙂
