RAID1+0 problem / fan noise / eternal sync ?
thiagotgc
After several days of testing ... I realized that my Gen 8 has stayed with the fan at 50% because of RAID1.
I put 4 disks in the bays, and ordered RAID 1 + 0 to stay on all day, and the HD usage light doesn't go out, and the fan gets 50%
I undid it, and left 2xRAID0, the FAN was 50% and the synchronization does not end, the light keeps on always ....
I undid it, and left it with 2xRAID1 and the Fan was 6%
I undid it, and left it with 4xRAID0 and the Fan was 6%
I'm testing with 4x500GB disks with the B120i controller
Does anyone know about this?
When I leave the disks without mounting an array, the FAN is 6% ....
But if I mount RIAD0, RAID1, or RAID1 + 0 the Fan goes to 30 ~ 50%
I see that the disk usage indicator led doesn’t turn off, there’s direct access ...
Very strange....
EDIT: I found that disabling the AHCI module, makes the disk usage led, stay on and on. When AHCI is activated, the indicator LED returns to normal.
Command used to disable:
esxcli system module set --enabled = false --module = vmw_ahci
However, when active, ESXi 6.5 no longer identifies the Array disks ...
Edited by thiagotgc
I realized that the problem with the disk usage indicator led occurs whenever I mount RAID1 or RAID1 + 0.
After he loads the hpvsa module on the ESXi, the disk usage indicator light comes on and does not go out.
When I leave in RAID0 1 in 1 or 2 in 2, the led works correctly
Does anyone have any solution for this?
Edited by thiagotgc
