emulemodes Posted March 9, 2020 Share Posted March 9, 2020 Hello, I bought a 1240 v2 processor. I installed Microserver Gen8. When I start, I can't get images from both ILO and VGA. Continuously restarting every 10-15 seconds. Beep sounds. Is it possible to have an idea with what is the reason or can help? Thank you. Link to comment Share on other sites More sharing options...
steeve Posted March 9, 2020 Share Posted March 9, 2020 Have you updated the bios before installing the new chip, as I think it needs updates to tell it to accept a non standard chip? Link to comment Share on other sites More sharing options...
emulemodes Posted March 10, 2020 Author Share Posted March 10, 2020 19 hours ago, steeve said: Have you updated the bios before installing the new chip, as I think it needs updates to tell it to accept a non standard chip? Bios and ilo are up to date. It plays with its internal processor but does not work with 1240 v2. The processor is in the meantime. Bios: J06 04/04/2019 ilo: 2.73 Feb 11 2020. Link to comment Share on other sites More sharing options...
pumek Posted March 13, 2020 Share Posted March 13, 2020 I had exact problem with different cpu. Check cpu socket pins Link to comment Share on other sites More sharing options...
emulemodes Posted March 26, 2020 Author Share Posted March 26, 2020 I changed the processor and the event was resolved. Thanks everyone. 1 Link to comment Share on other sites More sharing options...
