E3-1265L v2 temps
Amulos
Hi
I’ve just updated the gen 8 with the 1265lv2 and have been keeping an eye on temps And fans as I’m using the 35w heat sink.
It appears to idle at 30 ish ( based upon the hw monitor - software that in use ) .
Day to day usage is about 40-45 degrees , under load ( prime 95) it tops 85 , it’s only then does the case fan click up from 9% to 15% or so ( the temp for cpu on iLO is reported as 61 at this point)
is this to be expected or is it running too hot?
thank
