Embedded flash HELP
sutt359
Hi Guys
Could someone help please.
I went to use the intelligent provisioning and it said it couldn't be found. So I downloaded the update from HP v1.63
Now in the ilo its showing these errors, ive attempted to Format embedded flash and pulled the power and attempted format.
Controller firmware revision 2.10.00 Embedded media initialization failed due to media write-verify test failure
CPLD - PAL0 icon_status_06_informational.svg ProLiant MicroServer Gen8 System Programmable Logic Device version 0x06
Have you seen the embedded flash error. Controller firmware revision 2.10.00 Embedded media initialization failed due to media write-verify test failure
looks like I've lost access to the raid controller configuration page and can't boot media like dvd or USB sticks. But can get into the bios.
Edited by sutt359
