nrf 135 Posted June 28, 2019 Share Posted June 28, 2019 (edited) So they say when setting up the water sensor that it needs to be within 15 feet of the hub. what is the general distance these sensors can cover and still stay reliably connected? would I have to set up an array of zigbee repeaters? and how dependent is this setup on internet connectivity? if there is no internet can I still get alerts if I am on the same wifi as the sensor? Edited June 28, 2019 by nrf Link to post Share on other sites
nrf 135 Posted June 28, 2019 Share Posted June 28, 2019 which leads me to ask, how about a smartthings sensor + hubitat for those inclined to reduce dependencies on vendor cloud services? Link to post Share on other sites
schoondoggy 895 Posted June 28, 2019 Share Posted June 28, 2019 If I was buying a water sensor today, I think I would get one of these: https://aeotec.com/z-wave-water-sensor/ There is a dock for it, if you need to mount it and have the cables and contacts extended into a sump pump. This has contacts for two locations: https://aeotec.com/professional-z-wave-water-leak-tool/ Link to post Share on other sites
nrf 135 Posted June 28, 2019 Share Posted June 28, 2019 so do these hubs play nice with other vendors'sensors? Link to post Share on other sites
nrf 135 Posted June 28, 2019 Share Posted June 28, 2019 19 hours ago, schoondoggy said: If I was buying a water sensor today, I think I would get one of these: is this recommendation based on the company's reputation for reliability, interoperability, etc? do tell.. Link to post Share on other sites
schoondoggy 895 Posted June 28, 2019 Share Posted June 28, 2019 7 minutes ago, nrf said: is this recommendation based on the company's reputation for reliability, interoperability, etc? do tell.. It is not a recommendation, I have not tried this model. I have had very good luck with Aeotec products working with SmartThings. Aeotec Zwave devices seem to behave well with other Zwave devices. Aeotec devices do what they are supposed to do, reliably. 21 hours ago, Ncage1974 said: Thanks everyone for your feedback. I decided to go the samsung smartthings route. I found a decent deal for the hub on ebay ~$30 for a V3 Hub. The main reason i decided to decided to go the smartthings route is the water sensors are extremely cheap at $20 a pop. I only planned to use one initially for my sump pump but when they are so cheap why not add more right (water heater, toilet, sinks, bathroom, shower, ect...). The only thing i wish the sensors had is that lead that you run from the sensor to wherever you want but i'm sure they will be great how they are. Since i never used SmartThings i hope i don't have any issues with reach. I have a 2800 sq ft 2 story home. Don't know how well the protocols used by smartthings penatrate the walls. Hopefully better than standard wifi :). Thanks for the reminder that the SmartThings sensors are only $20. I just picked one up to try it out. Link to post Share on other sites
