matf Posted June 15, 2019 Share Posted June 15, 2019 (edited) Hi, I have a Gen8 Microserver running Win10, with 4 x 4TB drives, combined in stablebit drivepool. Each drive is setup as an individual array within iLO - so JBOD. Recently two of the drives reported bad sectors so I want to replace them. I've removed the two offending drives from the drive pool, and moved all files from them, but I'm just a bit nervous about the process of replacing them within iLO. The drives are E:, F:, G: and H:. It's G and H that have bad sectors. In Stablebit Scanner these are report as PHYSICALDRIVE 3 and 4. Using Speccy I identified the serial numbers of those drives. Unfortunately, when I go into iLo, the serial numbers are different (as reported in the Assigned Drives). So, Q1 - how do I actually identify the drives with the bad sectors in iLo? Given that they are PHYSICALDRIVES 3 & 4, can I assume they are located in Bays 3 & 4? (i.e. the two right hand bays). Q2 - What's the best way to remove them? Can I just physically pull them out and replace them (with potentially drives of differing sizes). Or do I need to delete the individual arrays they belong to? (Slightly nervous about that as it warns me all data will be wiped, so I want to be absolutely sure I'm deleting the correct arrays!). I do have all the files backed up, so I shouldn't lose any data, but restoring and reconfiguring would be a major pain in the butt. Edited June 15, 2019 by matf Link to comment Share on other sites More sharing options...
Trig0r Posted June 15, 2019 Share Posted June 15, 2019 I name my drives when I put them in, makes it easier to find them, disk 0101 is drive 1 in bay 1 for instance, I dont give them letters though, I just have the one letter for the pool... Link to comment Share on other sites More sharing options...
schoondoggy Posted June 16, 2019 Share Posted June 16, 2019 The process is detailed starting on page 19: https://support.hpe.com/hpsc/doc/public/display?docId=c03326739 Link to comment Share on other sites More sharing options...
