HP ML10 GEN 9 parts help
Warren89
Hello all, i am very new to all of this, i have a ml10 gen 9 with unraid on at the moment but i have used all 4 bays that come with it, can someone help or show me what i need or could doto be able to put more HDD in the system.
At the moment i have one for parity, one for cache and two for storage.
Hope someone can help.
Ok i have just opened her up all i need is another sas to sata cable Part No. 787091-001 any idea where i can get one of these or alternatives?
The manual does not show a mini SAS port on the system board. Is there a mini SAS port on your motherboard? Do you have any cards installed in the server?
Then you likely have a ML110 Gen9. Can you confirm?
https://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c04605708-5.pdf
For the four drives you currently have are they in swappable bays or mounted in the case?
Swappable drive bay options are documented starting on page 13 in the user guide listed above.
For the cable you asked about, ebay tends to be the best place to find those.
This is a good guide as well. Drive bay topics start on page 28:
https://content.etilize.com/User-Manual/1033728312.pdf
  • Thanks 1
  • 1 month later...
