[help] performance p222 microserver gen8
orcf
hi all
i need some help to understand if this values are correct.
i have installed a p222 on my microserver. i have installed ESXi 6.5u2 on it, remove ahci driver and put the old driver for b210i (88).
on p222 i configured 2 logical drives, one with a red western digital, the second 3 western digital on raid 5.
below a let the config and the benchmark of reading,
on the ESXi i have 3 vm machine.
  • openmediavault
  • ubuntu server 14.04
  • windows server 2012 r2
before i update the windows server the reading was 40MB/S now is 100 MB/s on the red western and the write was almost the same, i have on the pictures below.
all the test ware done  with only the windows server VM running and the other ones shutdown.
the VM openmediavault and windows server are on the western red and the ubuntu server are on the raid 5.
the c: drive is the red western digital and the e: drive is the raid 5
The config of the system
thank for the helping me if you can
Controller on System Board
Logical View
Physical View
Controller Status
 OK
Serial Number
N/A
Model
Dynamic Smart Array B120i Controller
Firmware Version
4.50
Controller Type
HPE Smart Array
Logical Drive 01
Status
 OK
Capacity
111 GiB
Fault Tolerance
RAID 0
Logical Drive Type
Data LUN
Encryption Status
Not Encrypted
  -Physical Drive in Port 1I Bay 1
Status
 OK
Serial Number
EB98075C10F000916495
Model
Patriot
Media Type
SSD
Capacity
120 GB
Location
Port 1I Bay 1
Firmware Version
SAFM12.2
Drive Configuration
Configured
Encryption Status
Not Encrypted
 Controller on Slot 1
Logical View
Physical View
Controller Status
 OK
Serial Number
PDSXH0BRH6U1CQ
Model
Smart Array P222 Controller
Firmware Version
8.32
Controller Type
HPE Smart Array
Cache Module Status
 OK
Cache Module Serial Number
PBKUA0BRH6U1J9
Cache Module Memory
524288 KB
  -Logical Drive 01
Status
 OK
Capacity
1862 GiB
Fault Tolerance
RAID 5
Logical Drive Type
Data LUN
Encryption Status
Not Encrypted
  -Physical Drive in Port 2I Bay 2
Status
 OK
Serial Number
WD-WCAW30727446
Model
WDC
Media Type
HDD
Capacity
1000 GB
Location
Port 2I Bay 2
Firmware Version
00.0NA00
Drive Configuration
Configured
Encryption Status
Not Encrypted
-Physical Drive in Port 2I Bay 3
Status
 OK
Serial Number
WD-WCAW30720650
Model
WDC
Media Type
HDD
Capacity
1000 GB
Location
Port 2I Bay 3
Firmware Version
00.0NA00
Drive Configuration
Configured
Encryption Status
Not Encrypted
§  -Physical Drive in Port 2I Bay 4
Status
 OK
Serial Number
WD-WCAW30732015
Model
WDC
Media Type
HDD
Capacity
1000 GB
Location
Port 2I Bay 4
Firmware Version
00.0NA00
Drive Configuration
Configured
Encryption Status
Not Encrypted
  -Logical Drive 02
Status
 OK
Capacity
1862 GiB
Fault Tolerance
RAID 0
Logical Drive Type
Data LUN
Encryption Status
Not Encrypted
 -Physical Drive in Port 2I Bay 1
Status
 OK
Serial Number
WD-WCC4M4FX1R5D
Model
WDC
Media Type
HDD
Capacity
2000 GB
Location
Port 2I Bay 1
Firmware Version
82.00A82
Drive Configuration
Configured
Encryption Status
Not Encrypted
