Best way to m.2?
Riquende
This year my plan is to totally replace the boot drives across my environment with m.2 drives. My desktop PCs are fine as they have the ports direct on the motherboard, but are there any particular differences in the pci-e expansion cards to get a port on the Gen 10, or are they all pretty much the same?
For the MS Gen10 you will need a card that is truly low profile. Cards must be no taller than the top of the bracket. In the link attached is a picture of the one I use. It has space for the M.2 NVMe SSD and a M.2 SATA SSD, the SATA SSD requires a cable to the 5th SATA port on the system board.
  • 11 months later...
hello
is possible to use the NVMe M.2 ssd as boot drive with windows or linux ? thank you
44 minutes ago, zzwcqyrshdjsaqbtepttirvorg said:
hello
Yes, but only if the BIOS is set to UEFI.
