Ambient Temperature Sensor replacement
CB1
Hi,
My temperature sensor has failed which causes critical system error.
I have 2 questions:-
  • Is there any harm in simply unplugging the sensor?
  • Where can I get a replacement sensor without being gouged by HP?
Thanks,
CB
Not sure where you are based, but I can see them on Amazon, not cheap though, part number 725205-001, unplugging it will generally cause an issue though as the system cant see it, so you'll probably still get a critical system error.
  • 4 weeks later...
Unfortunately I have the same problem with mine too at just over 3 years old...  Still waiting for my HP to advise where I can get the sensor.  Remember seeing a post that talks about firmware upgrade, so hunting this site for the link to the iLO firmware so I can upgrade it and see if it maybe a soft error.
PS. CB1 re-using your post so I dont start another one with the same questions.
PPS. CB1 just incase the firmware upgrade may fix your issue too.
I tried without the sensor cable plugged in and all that happens is that the ambient temperature shows -1C. I don't think that there are any adverse affects, apart from the fact that the fan speed calculation may be impacted. If you need a link to the firmware, send me a location and I will post the file.
Thought I would add my solution here in case anyone has a similar problem.
I cut off the transistor at the end of the sensor cable and soldered on a new one - 10 minutes work with a 50c part.
It now works perfectly, with the ambient temperature showing correctly.
The part is 2N3904 3904 40V - 200mA NPN General Purpose Transistor TO-92
Got 5 of these for $3.45 delivered
@CB1
I think I've broken the Sensor Cable when I trying to unplug the sensor cable(to upgrade the CPU), now the status page in iLO look like this, I can not boot anymore,
 Not sure it's related to temp sensor or the replaced CPU, but I tried to replace the CPU back, still the same problem.
Are you talking about the ambient sensor cable? If you unplug it you should just get the 01-Inlet Ambient being -1C and it should not affect anything else and should boot normally. I would update to the latest BIOS and see what happens. Also make sure that the memory is seated properly. What does the IML (logs) say?
@CB1
Thanks for your information, IML logs is empty(no information), also try to remove and replug memories and other parts.
Now I can confirm I may break the CPU socket in the motherboard when I trying to replace the CPU.
