NETGEAR Orbi Whole Home Mesh WiFi System with Tri-band – 2pk (RBK50) - $190
Dave
Factory reconditioned Orbi set. $189.99 on Woot.
Orbi delivers WiFi the way it should be—fast, reliable WiFi without dead zones and lag. Easy to set up and use, stream with superfast speeds on all your devices. Stream at high quality without buffering. With award-winning tri-band mesh WiFi technology, you always get the fastest internet speeds available.
Orbi blankets the whole home with steady WiFi so you can stream wherever you want, without worry. No more running around looking for a stable internet connection. Orbi makes WiFi easy. It takes minutes to set up with the Orbi app and already works with major Internet Service Providers so you can enjoy better WiFi sooner.
FAST WHOLE HOME WIFI SYSTEM - Covers up to 5000 square feet with high performance WiFi, kit includes WiFi router and Satellites
TRI-BAND TECHNOLOGY - Unlike other WiFi sets that lose speed as you add devices, Orbi routers maintain data flow for your connected devices using a dedicated backhaul connection
SINGLE WIFI NETWORK NAME - Provides seamless room-to-room roaming throughout your home
QUICK & EASY SETUP - No need to create new accounts; just download the Orbi app, plug in your system, and follow the instructions on your PC, Mac or mobile device to get your house on the net
GUEST NETWORK - Easily set up a separate and secure WiFi network for visitors and guests to use; the perfect web gear combo for movie streaming and gaming sessions with friends and family. Use the Orbi app or any web browser to create secure whole home WiFi in minutes. No accounts to create or personal information needed to setup.
COMPATIBLE WITH AMAZON ECHO/ALEXA - Control your home network using voice commands. Now includes Circle with Disney Smart Parental Controls - Manage your family's access to the internet by device, app, or website
