Need advice on cooling e3-1220l v2 & e3-1265l v2
oddstan
Case is 2u high. and both have 2 input and 1 output fan NF-R8 redux-1800 PWM
Is CNPS8900 good enough to handle e3-1220l v2 & e3-1265l v2 and keep case fans at low?
or it's better to consider something like NH-L9X65 (or NH-L9i / NH-L12s)?
one system will run two virtual machines. another pfsense with suricata and vpn.
If Zalman is ok will it fit in intel s1200btl & supermicro x9scm?
My only concern is about cpu fix and its plate on back of motherboards.
Maybe someone has experience in similar config.
Thanks.
Edited by oddstan
