4K BluRay Optical Drive
Joe_Miner
Looks like BU40N and BU50N are popular 9.5mm drives that appear to support 4k.
59 minutes ago, cskenney said:
I’m curious as well and what software is used with it.
Software for playback or ripping?
I'm thinking PowerDVD 18 but I'm open to suggestions......
Got one on order as well as a 32" 4k monitor -- I'm sure the grandkids will love it
  • 3 weeks later...
I think the hole is for an M3 countersunk, but the Gen8 ODD bracket does not work in the Gen10. I tried mounting the bracket upside down after drilling a small hole in it that aligns to the mounting hole in the chassis. I used a nylon screw to secure it, so as to not have any metal dust. It works, but it is not something I can manufacture. There are 3D printer plans for brackets that will work.
Thanks, watching the granddaughters today will talk more later
  • 3 weeks later...
