mSATA to USB Adapter for the Internal USB Port?
Notbugged
Does it work?
I know USB 2.0 will limit the performance but for boot drives I think it's fine... It's a very simple setup... no need floppy to SATA power, etc...
Reference: https://www.amazon.com/Adapter-Tanbin-Portable-External-Converter/dp/B075FR3ZD4
  • Thanks 1
It should work. Could be a good way to use some of the smaller mSATA drives I have lying around. A mSATA drive in this should be more reliable than a plain USB drive, different FLASH technology.
  • 1 month later...
ok my usb drive dead... suddenly unwritable....
i wonder if the first one maybe too "wide" to interfere with the case
and get the second one instead?
thx!
Edited by Notbugged
  • 4 weeks later...
This one works. I didn't use the metal case hope it reduces heat. Inside it looks somewhat similar to the first one above. Didn't try the other ones.
Edited by Notbugged
  • Thanks 1
