Synology MR2200ac Mesh Router announced. Works with RT2600ac
Dave
Synology just announced the MR2200ac Mesh Router.  It will be released on October 16th, 2018 and is currently $139 on Amazon Prime.   This is a tri-band mesh router that will talk to the RT2600ac but NOT the RT1900 model.  Synology will release SRM version 1.2 for the 2600AC that will allow the two units to talk, mesh, and add a whole bunch of new functionality for the RT2600AC including User Management, Time Management, Website Filters, and Website Browsing History.  This is in addition to all the security features that the RT2600ac already provides.
Screen Shot 2018-10-13 at 10.16.20 AM.pngScreen Shot 2018-10-13 at 10.18.51 AM.png
Amazon - $139 - https://amzn.to/2EiJ3yn
This is a nice addition to the already fantastic router/wireless AP system of the RT2600ac.
Screen Shot 2018-10-13 at 10.42.12 AM.pngScreen Shot 2018-10-13 at 10.42.05 AM.pngScreen Shot 2018-10-13 at 10.42.19 AM.png
Here are the stats and specs for the MR2200ac:
Hardware
Processor Quad core 717 MHz
Memory 256 MB DDR3
Antenna type 2×2 MIMO High Performance Hidden Antenna (2.4 GHz / 5 GHz)
LAN network Gigabit (RJ-45) x 1
WAN network Gigabit (RJ-45) x 1
External connection USB 3.0 x 1 (5V, 0.9A output power)
Button and switch WPS, power, reset, Wi-Fi on/off
Exterior
Size (height x width x depth) 154 mm x 199 mm x 65 mm
weight 0.45 kg
temperature
Working temperature 5°C to 40°C (40°F to 104°F)
Storage temperature -20 ° C to 60 ° C (-5 ° F to 140 ° F)
Relative humidity 5% to 95% RH
Warranty 2 years
other projects
AC input voltage 100V to 240V AC
Current frequency 50/60 Hz, single frequency
Power consumption 12.95 W (access)
5.21 W (standby)
wireless
IEEE 802.11ac
  • IEEE 802.11a/b/g/n/ac
  • Synchronous tri-band Wi-Fi
  • 5GHz-1: 867Mbps
  • 5GHz-2: 867Mbps
  • 2.4GHz: 400Mbps
IEEE 802.11ac wave 2 MU-MIMO
Wi-Fi encryption WEP, WPA/WPA2-Personal, WPA/WPA2-Enterprise, WPA2/WPA3-Personal, WPA3-Personal/Enterprise, Wi-Fi Enhanced Open (OWE)
Wi-Fi Mac address filter img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Network entity address filtering rule limit 64
Seamless roaming 802.11k/v/r standard support
Beamforming img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
DFS img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Scheduled Wi-Fi connection img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Guest network img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Visitor entrance img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Customized interface design img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Connection time limit img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Password rotation img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
WPS 2.0 (Wi-Fi Protected Setup 2.0) img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
3G / 4G NIC & USB Network Sharing  img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Maximum number of connected devices 90
Wi-Fi node img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Primary Wi-Fi node img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
network
Internet connection Dynamic IP, Static IP, PPPoE, PPTP, DSL-Lite (AFTR)
3G/4G LTE network card img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Android network sharing img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
iPhone network sharing img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Remarks iPhone network sharing only supports SRM 1.2 and newer Synology Router
Operating mode
  • Wireless Router
  • Wireless AP
Connection transfer Can be set manually or via UPnP
Connection transfer rule limit 64
UPnP rule limit 64
Connection trigger img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Connection trigger rule upper limit 32
Connection trigger timeout time lower limit 30s
Connection trigger timeout time limit 3600s
DMZ img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
IPv6 IPv6 DHCP server/client, DS-Lite, 6in4, 6to4, 6rd, dual stack, DHCPv6-PD, IPv6 trunk, FLET’s IPv6
DHCP Server/client mode, client list, MAC address reservation
DHCP reservation limit 500
LAN/WLAN IGMP snooping img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
VPN
  • VPN server (WebVPN, SSL VPN, SSTP, OpenVPN, L2TP/IPSec, PPTP, Site-to-Site)
  • VPN client (PPTP, OpenVPN, L2TP/IPSec)
  • VPN pass-through (PPTP, IPSec, L2TP)
Policy routing, static routing, network address translation (NAT), PPPoE forwarding
IPv4 static route limit 100
IPv6 static route limit 100
Diagnostic tools
  • Ping
  • Path tracking
Safe Access
Parental Control
User setting 15
Network settings 2
Customized network scheduling img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Hours of use img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
IPv4/IPv6 DNS-based web filter
  • schedule
  • database
  • Unblock request
Customized allow and block list
  • Maximum blocked URLs: 100
  • Maximum allowed URLs: 100
Interrupt network img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
reward img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Record img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Return img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
safety
Safe search Bing, Google, YouTube
Intelligent threat database Support for IPv4 and IPv6
Google Safe Browsing Support for IPv4 and IPv6
Automatic database update Threat Intelligence Database, Google Safe Browsing, DNS-based web filter
flow control
Network blocking, device speed limit, traffic priority img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Application layer (Layer 7) quality of service (QoS) img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Device rule limit 64
Application rule limit per device 32
data monitoring img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Instant image img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Historical statistics On a daily, weekly, monthly, and yearly basis
Website browsing record img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Application detection img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Traffic report img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Automatic location update img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Scheduleable img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Traffic analysis cycle On a daily, weekly, monthly, and yearly basis
Export format .CSV, .HTML
VPN Plus Server
VPN Plus Server Easily establish and manage secure access to VPNs through a web browser or client. Support multiple VPN servers: Site-to-Site, WebVPN, SSL VPN, Remote Desktop, SSTP, OpenVPN, L2TP over IPSec and PPTP
Maximum number of connections 10
Site-to-Site VPN img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Site-to-Site Tunnels 4
Remote desktop (RDP + VNC) 3
Contact list img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Kit center
Cloud Station Server Synchronize data across multiple platforms and centralize the history of all important files on your router
Maximum number of file sync transfers 64
Remarks Cloud Station ShareSync is not supported
DNS Server Finding and translating a web domain name is called an IP address.
Download Station Supported download agreement: BT/HTTP/FTP/NZB/eMule
Download task limit 50
BT task limit 20
Media Server (DLNA/UPnP®)
  • Multimedia index
  • DLNA compatible
  • Support for PS3/PS4/Xbox 360/Xbox One
RADIUS Server Fully integrated authentication, authorization, and account processing services for wireless network access
Mobile app
DS router (Android/iOS)
  • Initial installation
  • Network overview
  • Wi-Fi management
  • Wi-Fi system deployment
  • Safe Access
  • flow control
  • Network security (firewall, connection, transfer, internet blockade)
  • Wake on LAN
  • system update
VPN Plus (Android/iOS) img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
DS cloud (Android/iOS) img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
DS get (Android) img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
DS file (Android/iOS) img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
management
System Synology Router Manager (SRM)
Operating system upgrade (free) img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Access SRM anywhere Synology QuickConnect and Dynamic DNS (DDNS)
safety Firewall/SPI firewall, DoS protection, VPN passthrough (PPTP, IPSec, L2TP), automatic blocking, SSL authentication, security consulting center, two-factor authentication
Wake on LAN (WOL) img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Wake on LAN via QuickConnect img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Maximum number of connected devices 100
Message notification Email, SMS, push service (via DS router)
SSH img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
SNMP img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Set backup & restore img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
User account management img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Printer server Maximum number of printers: 1
USB / SD card file service
File system EXT4, FAT, NTFS, HFS+
Support access method
  • File Manager (local network only)
  • Web browsers: ChromeTM, Firefox®, Internet Explorer®: 11 onwards, Safari® 11 onwards
  • Mobile device: DS file
Supported communication protocol Windows File Service (CIFS), Mac File Service (AFP), FTP/FTPS, WebDAV
Apple Time Machine img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Shared folder permissions img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Storage space sleep img_5bbbb077a9cc9.png?zoom=2&w=640&ssl=1
Environment and packaging
surroundings RoHS compliant
Package contents
  • Host X 1
  • Transformer X 1
  • RJ-45 web route X 1
  • Quick Installation Guide X 1
