ML10 v2 fan upgrade/replacement
JustMe
Hi, can anyone tell me if there is a better (more silent) fan for this ML10 v2  on the market, a third party maybe? Mine is making a slightly rattling noise and I think is time for a new (better?) one.
Thank you.
I would also like a answer for that, the replacement part is simple, just the back fan of a ML310e or ML30 gen9..
but to replace it for a more silent one..
first off the connector is proprietary.
so although you could just replace the fan... there are more pins than just a 3p molex or 4p PWM on that connector.
second, ILO is setup to speed up and down the fan around sensors, so only if the replacement fan have the same of better performance at the same RPM then it will be usefull...
Oh, ok, got it. Thank you for your answer. Well, I'll look for an original replacement then.
