NBASE-T or MGBASE-T switches
schoondoggy
This one is not $300 but overall is a great value given what it has.  I have been running this one since it was released and I love it.  Has a lot of room for expansion.  I have 5 devices with 10G NICs hooked up to it.
https://amzn.to/2Ntcx0B
so going forward will fibre and copper be equally supported or will one tend to come out more cost beneficial in the long run? any prognosticators out there?
RJ45 connection:
The benefit of 2.5GbE and 5GbE is they meet the normal base-t spec of cable length, Cat 5e 100 meters. 10gbase-t is limited to 55 meters over Cat 6, but it looks like it will support 100 meters on Cat 6a. Standard copper Ethernet cable is easy to work with.
SFP+ connection:
SFP+ direct connect are cables with SFP+ transcievers and copper twinax cable. 1 to 7 meter passive cable and up to 15 meter with active cables. These cables are pre terminated to a specific length.
Moving to fiber extends distance;
Using SR short range SFP+ transceivers with fiber optic cable 10GbE can extend to 400 meters.
Using LR long range SFP+ transceivers  with fiber optic cable 10GbE can extend to 10 kilometers
Fiber is not user terminatable. Some switches require certain brands of SFP+. SFP+ transceivers are not always interchangable.
Cost:
RJ45 connections and Cat 5e/6/6a cable are much cheaper than SFP+ transceivers, Fiber optic cable and SFP+ Direct Connect cables, but used Mellanox SFP+ 10GbE NIC's are $30 on eBay.
Not seen the MS510TX before … looks like a handy piece of kit.
Could be a good piece of transition hardware e.g. cabling up both 1GB ports on a Gen8 Microserver one side … seeing 2 GB on the other … and so on as one builds in new systems with 5GB and 10GB ports.
UK price similar at around £240.
