Wake on Lan
StuMcBill
Hi,
I've got an HP Proliant Gen 8 Microserver with unRaid installed, and I was looking to install a script to set it to automatically sleep during hours I'm at work or sleeping.  However, to get it to wake again, I would need to enable wake-on-lan (presumably this would wake it if I started Plex (for example) on my Apple TV and tried to play a show).
I run the server headless, and don't have easy access to the BIOS - so I just wondered if the default was to have wake-on-lan enabled?  Or if there is anyway to turn it on headless?
Thanks,
Stewart
