Power Issues?
Trig0r
Anyone on here seen an SP4 have the issue where it refuses to charge, tried it with the dock and separate charger and nothing, both chargers work on my 2017 but the SP4 isn't having any of it..
Think it'll be written off and replaced
Does the light on the charge cable flash when plugged in? If it does plug in a USB cable into the usb port on the charger. That fixed mine.
Nope, nothing from the charger at all, same with the dock, just doesn't light up at all, will try something to draw from the PSU via USB and see if that sparks (pun intended) it into life..
Edited by Trig0r
