anxion Posted May 8, 2018 Share Posted May 8, 2018 Hi Guys, Any idea how i can replace fan in power supply? Any help Link to comment Share on other sites More sharing options...
MAdD Posted May 9, 2018 Share Posted May 9, 2018 Hi @anxion, maybe this will help: www.hpe.com/info/sml/ MAdD 1 Link to comment Share on other sites More sharing options...
anxion Posted May 10, 2018 Author Share Posted May 10, 2018 hi thanks but nothing about power supply fan replacing Link to comment Share on other sites More sharing options...
schoondoggy Posted May 10, 2018 Share Posted May 10, 2018 You would need to take the power supply apart to get the part number of the fan. Then you should be able to determine the size, voltage, RPM and CFM of the fan. Then you can search for an appropriate replacement. 1 Link to comment Share on other sites More sharing options...
