Doorbell Cameras
Trig0r
Who here has rolled out some sort of camera doorbell unit that works on both Android and iOS, properly while inside, and outside the home, over multiple devices simultaneously?
I'm looking for something that, in an ideal world, would ping a notification/call to unit based on location, so say someone rings the doorbell and I'm at work, but the FD is at home, so it picks her as the first point of call, before then moving on to the next and so on..
Seen a few devices that work while you are out and about but don't seem to properly work for multiple users of the same device pool.
My Vivint system works over multiple devices. All devices get the notice at the same time. We can all get the video at the same time. Not sure if we can speak through the doorbell at the same time though.
  • 6 months later...
  • 11 months later...
Still havent found something that does it, I think its more in the realms of a device that you can add little bits off code for, say the doorbell rings, it tries to ping a device on the LAN, if it cant, then it goes out to whatever cloud service and pings the devices that arent in the building..
I cant be the only person to think of or need this sort of thing surely?!
