SiliconDust - HDHomeRun Network-based Dual Digital - HDTV Tuner Ethernet Interface
joem
I have Comcast cable. I do not have a Comcast cable box. All of my TVs all have cable card. Will this product work for me? And if it does would it only be good for over the air telecasts or will it get all of my Comcast channels? Thanks. Any recommendations would be appreciated.
The current HD HomeRun products will pull ATSC and clear-QAM channels. That would be the over-the-air, and any channels that cable doesn't not have encrypted. You won't get all of them, most likely.
What are you going to be pulling into? An HTPC running Media Center?
Yes I will using it with a regular computer.
