JackoUK Posted March 30, 2018 Share Posted March 30, 2018 Overview I intend to design 2 new machines: a workstation and a data server, replacing an old workstation (of 7 years) and 2 data servers (5 years). While HP Microservers have proved to be inexpensive reliable machines, I am beginning to feel the constraints of only 4 disks and the slow speed of GbE networking … and looking towards the future with these builds. The pull of trying something new has nothing to do with it J Network Segmentation I view the network in 4 parts. 1. The WAN connection. My current ISP speeds of 40/20 Mbs are adequate. I could double that but I don’t use cloud backup (all local) or download much other than a few ISO’s and so feel no pressing need here. 2. The wireless network provided by the ISP’s commodity router is also adequate. The few devices I wish to connect are in the next room - no swimming pool in the NE of England! Again I could obtain a more powerful signal (from another ISP) if I chose. 3. The workstation and data servers are on a commodity Netgear GbE switch. Under failure conditions - a hard disk fails or on one occasion a server lost its RAID configuration and the whole server was potentially compromised - I find myself relocating TB’s of data. Now that disks are 8TB and still growing the time for recovery can run into days. Increasingly dangerous. 4. I’d like to relegate the GbE ports in 3 to access alone and create a 10GbE storage network. Fast Disk Subsystem Now there is no point in having 10GbE network bandwidth if the disk subsystem only has the bandwidth of a single hard disk (say 125MBs) … and I am attracted to the automatic parallelised rebuilding process across all disks which is supported by Storage Spaces under fault conditions. I am therefore of a mind to equip both the new workstation and the new data server with 8 disks apiece and configure a 4-column mirrored Storage Space on each … … but I’m not sure Windows will be up to the task (even if I go to Windows Pro for Workstations with ReFS). So I’d like to try INTEL software RAID and then a specialised RAID card if the software route doesn’t perform well. 10Gb Switching Although the price of 10GbE switches is coming down, I am inclined to treat the storage network in the manner of a 2-node, hyper-converged cluster and direct-wire a separate subnet between only 2 machines, avoiding the need for 10Gb switching altogether (at least in the first instance). This idea solidified when I looked at page 34 of this Microsoft working paper. I have also found much inspiration and useful information on the Cinevate site and the questions discussed on this site. Attachment: Network diagram Component Selection Since both old machines are to be replaced rather than modified, the idea of purchasing motherboards with in-built 10GbE capability surfaced. The ASROCK range looks especially suitable with either Aquantia or Intel Thunderbolt circuitry on board … and sometimes both, providing a link to newer laptops which tend to have TB built in. Data Server Option 1 Motherboard Fatal1ty Z370 Pro Gaming 7 245 CPU I3-8100 3.6GHz 4 cores 99 RAM Corsair dual channel 2 x 8GB 170 Video Intel 620 on CPU PSU Corsair CX550 550W 55 SATA DISKS Intel RAID 5 on 6 + 2 8 SSD DISKS Kingston 60GB 40 Case Fractal design R5 8 disk bays 100 LAN On board 2 x 1GbE Thunderbolt Header on board Storage Aquantia on board 10Gbe BaseT TOTAL £709 Given that a new dual core, 8GB Gen 10 microserver is £306, that’s not bad. The cost of the OS and disks are omitted for the present since they are often common to different systems. Performance questions remain: - How well will the Intel software RAID work with 6 disks? - Is the i3-8100 powerful enough to perform the RAID computations and fill the disks? - How good is the Aquantia silicon? Why Not a NAS? The Synology 1817+ goes for 983 in the UK with: Intel Atom quad core CPU at 2.4Ghz 8GB RAM (max 16GB) 8 disk bays The dual port 10GbE add-in is 307 … and is SFP not 10BaseT TOTAL £1,290. At its maximal configuration there seems to be little flexibility and no room for expansion. A Real Server? My favourite HP Ml110 Gen 10 configuration goes for 1355. XEON Silver 4108 8 core 1.8GHz base, turbo 3 GHz 16GB ECC RAM in one slot 550W PSU Software RAID S100i for 8 disks 10 SATA ports, 6 memory slots, 5 PCI slots including two at x16 So adding in: - Small SSD for the OS 40 - 2nd 4-bay LFF drive cage 138 - INTEL dual port 10GbE NIC X540 T2 180 TOTAL £1,713 Smashing machine but too rich for my blood. Maybe one of our gurus will take such under his wing? Workstation The design uses the same motherboard as the data server … I have one eye on testing the data server and if it does not live up to expectations, convert it to a workstation: I am not a qualified builder or system administrator! Motherboard Fatal1ty Z370 Pro Gaming 7 245 CPU I7-8600 3.2GHz 6 cores 280 RAM Corsair dual channel 4 x 8GB 340 Video nVidia GTX 1050 2GB 140 PSU Corsair CX650 650W 83 SATA DISKS Intel RAID 5 on 6 + 2 8 SSD DISKS Samsung 960 M.2 NVME 256GB 109 Case Fractal design R5 8 disk bays 100 LAN On board 2 x 1GbE Thunderbolt Header on board 2 x 40GB TB 73 Storage Aquantia on board 10Gbe BaseT TOTAL £1,370 Testing Disk Performance No doubt the general recommendation will be use a hardware RAID card but I would like to see for myself how INTEL software RAID 5 performs on a modern CPU. I would also like to test the performance of a 4–column Storage Space, without and maybe with ReFS – so Windows 10 Pro for Workstations. Before testing I need to identify … probably ¾ … of my data for cold storage. Realistically I rarely look at it and indeed may never look at some of it again. The 2 servers taken out of service can be secured with the cold data for the rare occasions the same is required. Testing Networking I’d also like to test Windows SMB Multichannel on my remaining Gen 8 microservers, both of which have 2x1GbE ports, and the new machines. I’ll need to master how Windows handles multiple NIC’s on the same machine. And of course correcting/tuning the 10GbE link. Your turn! Link to comment Share on other sites More sharing options...
Poppapete Posted March 30, 2018 Share Posted March 30, 2018 Very interesting. Questions & Observations. Is i3 4 core a bit underpowered for the data server? What is the TB connection to laptop used for? Will you need to do any transcoding for your video streaming? What media server will you use? Very important to get a case and motherboard that will handle lots of disks as you will always need more. What JBOD do you intend to use and what card to support them? Cisco bought into Aquantia early this year!!?? Link to comment Share on other sites More sharing options...
JackoUK Posted April 3, 2018 Author Share Posted April 3, 2018 (edited) Answers (and evasions!) Q1. Is i3 4 core a bit underpowered for the data server? A1. Probably not ... because much lower specification parts appear to be enough for NAS devices offering 10GbE (e.g. the Synology 1817+). But if it is I just buy an 8600 and recover some of the £99 from the 8100. Q2. What is the TB connection to laptop used for? A2. Transferring files ... but this is not a major requirement, more of a 'future proofing' measure. The availability of mobos with both 10GbE and TB allows the possibility of adding a high-end laptop later. I can only see USB-C and TB becoming more common. The marginal additional cost is negligible. (Further ... though not explained ... I have one eye on a modern laptop as the workstation. High-end laptops are now quad-core with 2 TB ports, so I could use one for the data server and the other for a 4K monitor.) Q3. Will you need to do any transcoding for your video streaming? A3. Dunno. I believe I've nailed audio on Windows 10: files on a Gen8 Microserver; wireless connection to the streamer; remote desktop to the streamer from a tablet on the sofa. The bandwidth for even DSD is way below wireless. Can I turn this question round? What would make a good 4K streamer? If my CHUWI Hi13 tablet will do, done. If not, surely a modern laptop will be enough (overkill probably): I am either at home watching video using a tablet ... or on holiday using the laptop. I've posted in a few places asking if anyone has an end-to-end 4K streaming design. NETFLIX are saying 15Mbs ... easy for home wireless. What problem do you see? Q4. What media server will you use? A4. First copy of all data will be on the workstation. 2nd copy on the data server. 3rd (backup) copy in the garage. Q5. Very important to get a case and motherboard that will handle lots of disks as you will always need more. A5. Covered by scaling out. The mobo's 10GbE port will be connected directly to the 10GbE port on the data server. If I want another 8 disks ... I buy another 10GbE card for the workstation and another data server with 8 disks. So I don't need more disk bays, I need more PCI slots. Note too that since the workstation and data server both have 2xTB (the ASROCK card has 2 ports) ... I could chain TB data servers instead of adding 10GbE PCI NIC's. Q6. What JBOD do you intend to use and what card to support them? A6. Not clear from my explanation but DATA4 and DATA5 are just my 2 existing Gen8 Microservers. Backup to them can run at its own speed when I can be bothered or I make a mistake. Indeed I hope only to use them if the hosue burns down: with RAID 5 an workstation and server I would be unlucky to see both devices compromised. "Cisco bought into Aquantia early this year!!??" Sounds good for the long term viability of AQ ... and cheap 10GbE networking ... oh.oh, ... need to take a rain check on the cheap. Buy now! Edited April 3, 2018 by JackoUK Link to comment Share on other sites More sharing options...
JackoUK Posted April 3, 2018 Author Share Posted April 3, 2018 (edited) One other motherboard interests me - the Gigabyte UD4. https://www.amazon.co.uk/Gigabyte-Intel-X299-UD4-Chipset-Motherboard/dp/B072VL89BZ/ref=sr_1_1?ie=UTF8&qid=1522770425&sr=8-1&keywords=x299+ud4 Although it has a TB connector there is only 1 GbE port and crucially no 10GbE ... but it has other redeeming features: - it is X299 - all 8 SATA ports are exposed to Intel software RAID - low cost than the fancier ASROCK equivalent Data Server Option 2 Motherboard Gigabyte UD4 185 CPU i5-7640 4.0GHz 4 cores 115 RAM Corsair Dual 2 x 8 GB 170 Video nVidia GTX 1050 140 PSU Corsair CX550 550W 55 SATA Disks RAID 5 on 8 8 M.2 Disk Samsung 960 M2 NVME 256 GB 109 Case Fractal Design R5 100 LAN on board 1 x 1GbE Thunderbolt Dual TB add in card Yes 53 OS W 10 Pro OEI 130 1057 TOTAL £1,057 In various ways this is a more balanced system ... ... and the X299 chipset affords great extensibility: the CPU could be upgraded to a 7800X or even a 7900X and beyond, opening up all the PCI lanes. Edited April 3, 2018 by JackoUK Link to comment Share on other sites More sharing options...
Poppapete Posted April 5, 2018 Share Posted April 5, 2018 (edited) I like that 2nd MB option, much better in most aspects. By Media server I mean "What media software" do you use? Plex, Serviio! It seems you are only serving media to a few laptops not 3 Sony TV's like I am! Also I have to worry about VPN's so we in Australia can get BBC iPlayer and Netfix USA. Edited April 5, 2018 by Poppapete Link to comment Share on other sites More sharing options...
JackoUK Posted April 5, 2018 Author Share Posted April 5, 2018 I don't use any media server software for video or audio ... I only use players accessing remote file systems and pumping data into the target device. If I want to listen to Vokuro I switch the audio file server, streamer, tablet and hi-fi on. I remote desktop from the tablet to the streamer and then navigate in File Explorer to ... /Network/HPMS3/Music/Pop/90s/Bjork/Medulla/Vokuro.flac ... and double-click, which brings up Groove (or Foobar if the file is DSD not PCM). If I wanted music in another room (I don't) then I'd just add another streamer. I'm expecting to do the same for video when I get a 4K TV: double-click /Network/HPMS4/Videos/Family/Holidays/Azores/Terra Nostra Gardens.mp4 No problem with VPN: the streamer is Windows 10, so I'd just slap IPVanish thereon. Of course we natives back in Blighty have a BBC account old chap ... ... watch American TV? You cannot be serious! Link to comment Share on other sites More sharing options...
JackoUK Posted April 5, 2018 Author Share Posted April 5, 2018 The final option I've been researching follows the release of the C3000 CPU ... https://www.servethehome.com/denverton-day-official-sth-intel-atom-c3000-launch-coverage-central/ ... which looks like a very good match for a storage server: - low power consumption - ECC - lots of SATA ports - 10GbE ... but I can't find a motherboard I like ... and no Thunderbolt. Link to comment Share on other sites More sharing options...
JackoUK Posted April 26, 2018 Author Share Posted April 26, 2018 Changed my mind about the i3-8100 ... considering that it is only c£50 more expensive, the i5-8400 with 6 cores looks much more cost effective and powerful. Found a server grade motherboard I like now: Gigabyte MB51-PS0 https://www.servethehome.com/gigabyte-mb51-ps0-review-big-intel-xeon-d-platform/ 14xSATA ports and 2x10GbE BaseT ports. Could be expensive Case? Maybe http://www.lian-li.com/pc-a79/ 2 ports for SSD 12 ports for 6 column Storage Space. Link to comment Share on other sites More sharing options...
JackoUK Posted October 22, 2018 Author Share Posted October 22, 2018 (edited) More ideas after further research and some new product announcements. Just when I became happy with the i5-8400 … I noticed the ‘T’ series processors e.g. i5-8600T. With a lower power consumption of 35W when idling and turbo to 3.7GHz when motoring they seem well suited to a home data server role. However I can’t find anywhere that sells them! An i9 setup looks great … but the power consumption and cost is huge. I really liked this motherboard too: https://www.servethehome.com/supermicro-x11sph-nctf-atx-storage-motherboard-review/ but the value of the XEON CPU’s is terrible. 8 disks/SATA ports/bays seemed to be pretty much the general limit without expanding into external cabinets … … until I started reading recent announcements by ICY DOCK. That company is developing a range of compact disk bays to fit in the obsolete 5.25 bays still contained in tower cases. For example it is possible to fit 4 by 15mm disks into a 1 by 5.25 bay using: https://www.icydock.com/goods.php?id=254 The idea here is to buy an inexpensive JBOD HBA for an additional 8 SATA ports opening up the possibility of a 16 disk Storage Space – an 8 column mirror. 8 of the bays would be 3.5” disks fed from the motherboard and another 8 fed by the HBA. Now 15mm disks means a limit of 4TB per disk and a little more expense of course … … but theoretically those 8 columns should be getting somewhere near filling a 10GBE network connection and a 4TB disk failure shared out between 7 columns rebuilding in parallel should be over pretty quick. I should add that I’ve never got anywhere near testing any of this! The ICYDOCK solution is splendidly general, opening up the choice of case. My current preference is the FRACTAL DESIGN R5 for its quietness, 8 x 3.5” bays and 2 x 5.25” bays. http://www.fractal-design.com/home/product/cases/define-series/define-r5-black Indeed one can even contemplate the FRACTAL DESIGN XL R2 with 4x 5.25” bays for a 24 disk system. http://www.fractal-design.com/home/product/cases/define-series/define-xl-r2-black-pearl ICY DOCK are also heading (but not there yet) in the right direction by employing mini-SAS connectors. Clearly we would prefer to combine SATA cabling in bundles of 4 with a 16 disk system! Edited October 22, 2018 by JackoUK 1 Link to comment Share on other sites More sharing options...
JackoUK Posted January 3, 2019 Author Share Posted January 3, 2019 (edited) Thinking about a workstation … and looking at the New Year Sales at the DELL Outlet … I put a reserve on this offer at 1450: 7920 workstation Silver 4110 CPU 2.2 turbo up to 3.0 with 8 cores and room for a 2nd CPU Windows for Workstations 4 cores Plus 24 memory slots with an initial 2x8GB ECC RAM Radeon Pro WX 5100 GPU with 8GB DDR5 4 HDD bays with 1 TB for the OS … thinking I could add the 5-8 HDD 'customer upgrade kit installable by the user', the PCIe NVME drive sled ... … and eventually a 2nd CPU and more memory. My hopes were soon dashed though when I asked to order some additional items. No chance. I couldn't believe no upgrades were allowed on such an expandable machine. Who keeps their machine the same through all its life? Anybody here tried to upgrade a DELL workstation - what works and what are the likely roadblocks? Edited January 3, 2019 by JackoUK Link to comment Share on other sites More sharing options...
